Old 12-28-2023, 08:31 PM   #1
Casper42
Casper42's Avatar
Cab body cushion bushings
I just replaced my cab mounting hardware on all four corners, including bolts, washers, crush sleeves and rubber "OEM" bushings (aka cushions).
After doing some research, I found that there were currently only two types: the "OEM rubber" kit, or the Urethane kit for a performance stiffer ride. Mine are OEM rubber kit from Classic Industries but look just like all the others being offered by LMC, Holly, etc. They certainly don't look like OEM, but this is now what we are being offered unless one get's lucky to find NOS bushings. My research found these kits with no issues from other customers. However, I had to be creative and use additional washers between the cab and the frame to achieve spot-on body line symmetry from the cab to the bed. The problem with the current product, when comparing the thicknesses of the bushings, the new ones are actually about 1/8 of an inch thinner than my squashed down 51 year old OEM cushions. Seems very odd the new would be thinner.
I should point out that Brothers/Holly has an old video (Youtube) of how to replace these, and the ones at the time look near spot-on to OEM and they also point out in the video that the rear bushings are thicker than the front: the new kit they are all the same thickness. If this is the case, why doesn't Brothers/Holly offer this older version? Incompetence?
Have others found problems such as I described?
And yes, I did report my concerns of all this to Classic Industries by way of customer review.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 12-29-2023, 09:24 AM   #2
Jason Banks
Jason Banks's Avatar
Re: Cab body cushion bushings
Here's a link to a different style...
https://www.classicparts.com/1967-72...info/35%2D145/
I used this set on a truck and within a year the front cab mounts seemed to be compressing and I went back in and added a shim. I'm not totally convinced it was a product problem and not an installation problem. Did I over tighten the front? Did I not have enough shim under the core support and when I tightened it, pulling down on the front of the cab?
Either way, I just ordered a set for a different truck and opted for the other less original style.
Jason Banks is offline   Reply With Quote
Old 12-29-2023, 01:17 PM   #3
Casper42
Casper42's Avatar
I did not see these, thanks. I suspect you might be right by you over-tightening. By looking at that OEM style, such as what came on our trucks and what Classic Parts offer, they sure seem as though one needs to pay attention to how tight you get this by putting more trust in the lock-nut, compared to wrenching it down. My style seems far less likely to over-tighten as they are less likely (IMO) to compress.
Old 12-29-2023, 02:15 PM   #4
MikeB
MikeB's Avatar
I've had the same set of Prothane cab-to-frame bushings on my C10 since the mid 1990s. They still look like new, are not affected by ozone, and will never let the cab sag. And I doubt I'd notice a difference in ride quality using rubber bushings. After all, it's a truck, not a Cadillac.
I've also used Energy Suspension or Prothane bushings on the suspensions of all the other old cars and trucks I've owned, from a 55 Chevy sedan to an 82 C10.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-29-2023, 03:51 PM   #5
HO455
HO455's Avatar
Maybe contact Wes at Classic Heartbeat. The ones I got from him for my Burban looked to to be spot on OE reproductions.
http://67-72chevytrucks.com/vboard/s...d.php?t=808538
RIP Bob Parks.
Old 12-31-2023, 12:22 PM   #6
MikeB
MikeB's Avatar
Originally Posted by MikeB View Post
I've had the same set of Prothane cab-to-frame bushings on my C10 since the mid 1990s. And I doubt I'd notice a difference in ride quality using rubber bushings.
Earlier I said I'd doubt I'd notice a difference. Have any of you ever done a direct comparison -- new rubber vs. poly? I've only done worn-out rubber vs. poly.
Mike
Old 12-31-2023, 02:17 PM   #7
Casper42
Casper42's Avatar
within the past year, I've done a pretty large amount of research from various forums and parts supplier reviews. My take was the consensus was poly was not recommended for anyone wanting a comfortable drive. Several customers stated it was just to harsh and they replaced or wanted to replace with rubber.
Old 12-31-2023, 02:34 PM   #8
MikeB
MikeB's Avatar
Interesting. When I installed the poly cushions in the 1990s, the only difference I remember is the doors closed easier! But, again, those were some really worn out rubber cushions. I had actually bought them from a Chevy dealer, but they lasted only a few years. Maybe they had been sitting on the shelf, exposed to the atmosphere way too long. NOS with an emphasis on OLD.
Mike
Old 12-29-2023, 03:55 PM   #9
Jason Banks
HO455 I forgot, if you need anything rubber for the trucks Wes is who to get it from:
Link to mounts on his site: https://www.classicheartbeat.com/pro...ing-1967-1972/
He's closer to Casper42 anyway
Old 12-29-2023, 04:53 PM   #10
Getter-Done
Getter-Done's Avatar
Is the ones from GMC Paul's okay?
That's the one's I purchased.
84 Chevy K-20
Old 12-30-2023, 11:55 PM   #11
Casper42
Casper42's Avatar
UPDATE: despite the need to add washers to build up the thickness to get body lines correct, the test drive with the new bushings is very nice. There is now no noticeable "old car" body lean in roadway curves. It handles the roadway imperfections, like potholes, closer to a newer truck than a Cadillac.
Old 12-31-2023, 01:06 AM   #12
pjmoreland
pjmoreland's Avatar
Here's a photo that compares one of my original bushings to one from GMCPauls. The last two photos are the GMCPauls bushings installed.
pjmoreland is offline   Reply With Quote
Old 12-31-2023, 11:06 AM   #13
Getter-Done
Thanks for the pictures.
That looks about right.
There was not much left of mine to compare.
84 Chevy K-20
Old 12-31-2023, 02:24 PM   #14
Casper42
Casper42's Avatar
Excellent! nice side/side and install pix. Hopefully those will last you a lifetime, or at least another 25-50 years. I suspect my non-flared cushions will last a bit longer, simply because of that non-flare.
Old 12-31-2023, 07:12 PM   #15
Ricks1971
Ricks1971's Avatar
I bought a 71 4x4 and they had replaced the bushing with a Urethane kit and they took the truck off road and when I got the truck home the rear bushing on the cab actually crack rge can and I had to weld it up and put rubber bushing back in. A lot better ride
Ricks1971 is offline   Reply With Quote
