Dakota digital tail light circuit
1970 c10 - dakota digital HDX gauges - the instructions say for the module dim(+) connection to hook it to the taillight circuit.
The dim(+) is for the backlights and needles on the cluster to illuminate when the headlights are turned on. What wire should be used? Could I use the grey wire that illuminates the dash lights from the factory wiring that is in the factory plug that goes into the back of the original cluster? (Actually new M&H factory upgrade replacement dash harness) that factory plug also holds the left and right turn signal, high beam, etc wiring for the cluster. If i can't or shouldnt use that one, where from / how did you get the source for that dim(+) connection? Any help would be so awesome.thank you so much. ~ Lorenzo |
![]() Join Date: Dec 1999
Re: Dakota digital tail light circuit
I believe that is the wire I used for my RTX gauges. I remember getting everything I needed from the factory cluster plug.
I'd check, but I no longer have the truck. Here's a picture. I believe that grey wire is top left. |
