01-05-2024, 08:33 PM | #1 |
Hub Cap Removal Tool
I just had my Accuride rims powder coated and wanted to see how some stock hub caps would look with the new color of the rims (spinnaker white). I could NOT get the hub cap off (without scratching the rim). I spent a lot of time searching flea markets and swap meets for these decent hub caps (12" 4X4) so any more scratches or dents were not ok. It took a few minutes to come up with something to get them off without damage but here it is, it worked perfect and no scratches on the rims or caps. I have some 3/8" stainless rod to make exhaust hangers, so I used that along with a torch and a ball peen, added a small section of old hose at the pivot. The new tool needs to be applied as close to the "nub" on the rim as possible. I installed and removed the cap probably 15 times. I did notice on the rims that the four "nubs" are two different styles. It looks like two have a little more of a "hook' to them and then the other two are a little smoother to keep the cap centered. When I was using my new tool it worked best when applying it next to one of the nubs with the deeper hook. I have an original 72 eight lug rim and it also seems to have the two different type of nubs, but maybe I'm just making that up....idk. Enjoy!
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
01-05-2024, 08:44 PM | #2 |
The Niner
Re: Hub Cap Removal Tool
Or $10 at Harbor Freight for these.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
01-05-2024, 10:02 PM | #3 |
So you use these to remove your caps? Which one doesn't scratch or dent the cap?
01-05-2024, 11:37 PM | #4 |
They're plastic, so they're not likely to scratch the paint.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-06-2024, 12:35 AM | #5 |
Plastic? That's not going to work on my caps and the Accuride rims. These things are tight and that's a good thing. Maybe they might work on the old rusty original rim I have but not the new fresh ones.
01-06-2024, 04:35 PM | #6 | |
The Niner
My rims were powdercoated and those caps were on there tight, but they came off with those plastic things easy-peasy.
01-05-2024, 09:54 PM | #7 |
I have two that work, and one that's perfect for the application. It's the top of the middle tool in the group above.
Regular cap removers are a big no-no.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-05-2024, 11:50 PM | #8 |
This is the one I have and I recommend it.
https://www.amazon.com/gp/product/B00GWFOSBY |
01-06-2024, 12:41 AM | #9 | |
Yes, very similar to what I made (for about $10) and it should outlast me and my truck.
01-06-2024, 01:25 AM | #10 |
OC,
I just use a small (6-7") 90* crow bar, but with a piece of scrap leather that protects both wheel and cap. But mine is all stock...no problem. But those caps, on that wheel, no way mine would work. Really nice adaptation and tool fab you did there for your unique application. Nice job.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
01-06-2024, 02:21 AM | #11 |
Could just dip your metal tools in "Plasti Dip": https://www.homedepot.com/p/Plasti-D...03-6/202196703
1970 C10 Custom longbed 350/350 |
01-06-2024, 07:06 PM | #12 | |
01-06-2024, 03:53 AM | #13 |
Plastic or no plastic, if your wheels are nice tape up the contacts. Otherwise you scuff the wheels up.
It's worth mentioning, I noticed my original wheels are designed so there's a gap between one nub and cap. That's for prying. Sometimes that space is inconvenient, so just spin the tire. I couldn't get my bar similar post 6 to work. Perhaps if I grinded the tip thinner, and sand paper to 3000 grit
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-06-2024 at 04:02 AM. |
01-06-2024, 10:25 AM | #14 |
Nice tool that does what you need it to do, thought up and created by you in your shop using what you had. This is what it's all about. I do something different. Well, everyone does because yours is the only one! I do something different but I see no point in recommending using anything else. Great job. And you are correct in prying right next to the nub
I always ran 9.75"w rims with hubcaps, but way back the hubcaps weren't made of gold and I didn't start powder coating wheels until the late '80s. The first time I got a flat I went into my (carpentry) tool boxes and grabbed a cat's paw (nail puller). It worked perfect for deep dish rims that made removing even harder. I always had that tool in my truck, so I was all set. If that chipped the paint it was only a time or two and no big deal. I never damaged a cap doing this. My painted wheels I would refinish every few years anyway. I did it the same once I started powder coating my wheels. On the '72 K/20 Cheyenne Super Custom Camper I had, what I consider my first collector truck, I chipped a wheel...argh! That's when I started grabbing a rag, cardboard, or leather to lay between the tool and wheel. But now that wheels, hubcaps, and powder coating cost so much I finally bought my 1st hubcap removal tool. It was cheap and it works perfect for both removal and dent-free installation. I've only used it on Accurides, probably won't work on wide wheels. I have all kinds of plastic pry tools and they just flex on these tight fitting caps. Most things you don't want to scratch only require light prying and these work well for that. But with hubcaps it's tight fitting lightweight metal requiring some hard prying that I find the plastic pry bars no good for.
01-06-2024, 07:24 PM | #15 | |
01-06-2024, 11:43 AM | #16 |
The tool you made works for you and gives you the satisfaction it's not going to mar your wheels, and that's all that counts....IMHO.
01-06-2024, 04:17 PM | #17 |
Interesting post ! Think I use the O.E. lug wrench that came in my C -10 . Probably marks up the wheel but that's ok . Steelman tool looks like a good solution . Thanks .
01-06-2024, 10:26 PM | #18 |
It's nice to run the correct caps and the all original look is great. But nothing wrong with the next design and I can't honestly say one looks any better than the other. They both look equally great, but when correct matters original looks best. It's like arguing over which custom wheel looks best
01-07-2024, 12:39 AM | #19 | |
01-07-2024, 01:11 AM | #20 |
The Niner
I did the raw dog look on my old 69 C/20 till I found the right hubcaps. Looks better on a K/20 than a C/20
01-09-2024, 11:06 AM | #21 | |
I have N.O.S. caps for my truck but my truck isn't cherried out. So mine runs open wheels. My trucks is a Day 2 truck, so I want to dismount my tires and get my wheels powder coated gloss black. I tossed in a picture of an '84 I did the black powder coat on 9.75s. I run the 2.5" chrome lug nuts with open wheels. The member's K/20 shown with open wheels and headache rack is exactly how I recall the trucks in the western mountain states being in the '70s. A no BS 4wd truck
01-07-2024, 01:03 AM | #22 |
I just picked up these "Craigslist Special" GMC 12" center caps to put on my deck over trailer as soon as I get my grandson over to pull, mask and paint the wheels white.
