01-11-2024, 01:43 AM | #1 |
10,000 GVW on vin tag?
There's a 1969 longbed 3/4t 4x4 manual trans with a 454 at a auction with 10,000 GVW on the vin tag on the door jam. Don't think I've ever seen one. Anyone else seen something like this before? also has the DD below the vin. I've seen that before.
Last edited by 67sss; 01-11-2024 at 02:08 AM. Reason: edited correct year to 1969 instead of 1972 |
01-11-2024, 01:48 AM | #2 |
Re: 10,000 GVW on vin tag?
That does not look like a 72 vin tag. Also, if a 72 4x4 the vin would start with CK. A cab swap at minimum. Another tell tale is a big block was not available in a 4x4.
Looked it up, Vin is 1969 1 ton 2wd cab and chassis built in Fremont California
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 01-11-2024 at 02:04 AM. |
01-11-2024, 03:38 AM | #3 |
See you edited your post for year. I also edited mine with the correct truck ID per the vin. Cab and chassis was 2wd, came with no bed. No big block or 1 ton in 4x4. So cab, bed, chassis and motor are all from different vehicles. Maybe fenders and hood are original to cab? Short story, the truck was put together with a bunch of pieces. Did they do a good job?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-11-2024, 07:28 AM | #4 |
1t cab swapped onto a K/20 chassis. Need to check if it's a 67-72 chassis or a 73-87
