![]() Join Date: Feb 2022
Hood hinge spring orientation? (Clocking)
My da... ADD has got me obsessing on the orientation or clocking of the spring as it is mounted on the hood hinge. Are the ends of the spring oriented with the end facing up or down. I search with no result. It likely does not matter but I can't release my brain and it's driving me nuts. Thanks all for understanding.
#2 | |
![]() Join Date: Mar 2011
Re: Hood hinge spring orientation? (Clocking)
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: Dec 2009
Here is a link to 12 sets a member had for sale.
Link: https://67-72chevytrucks.com/vboard/...ht=hood+hinges
Thank you. Given your project is some what mod custom I am still questioning as it is so easy to rotate. I put them on today clocked same as you did but did the factory do so or clock 180 for some some reason not appearent to the average shade tree mechanic? .
By the way. Really nice paint. Looks good |
![]() Join Date: Apr 2016
I have no reason to believe my hood hinges have ever been messed with, the whole truck appeared original and had 86,000 miles on it as of the 1980s. Based on wear and tear of all the items on the truck I believe it had not been over 100,000. The passenger side has the spring with the ends pointing up, and driver side pointing down. I think they were installed whichever way was convenient to the installer. Release your brain and enjoy them in any orientation. Naturally I would like to see yours with passenger side spring with the ends pointing up, and driver side pointing down, doesn't that counterbalance the Chevy frame twist? Or cause it, I don't remember. :-)
#6 | |
The following is for PbFut... Here's an item you can add to your ADD list.. Jack up your truck and check the clocking on the nuts on the bolts holding the bed in place.. You'd be surprised in the improvement in ride quality when they're all clocked in the same direction.. ![]() ![]() |
LOL. Great Saturday morning humor. Looking at the thread Getter-Done posted, it seems like most are pointing down. Now to get the valve stems clocked
If you having already changed your Summer air to Winter air,
It would be a good time to do that while you are clocking your valve stems. ![]()
