Frozen Door Handles ?
We have had below zero temperatures since last Friday, negative 17 ! Yesterday I tried to open the door on my C/20 but the button would not budge. Years ago I would have tried and probably broke something inside the door. Getting older I’ve learned to just walk away and give the situation a think before doing damage. Any suggestions on what is actually stuck ? Is it just the push button or the inner door parts ?
71 C-20 07 Magnum RT AWD |
![]() Join Date: Jun 2022
Re: Frozen Door Handles ?
Any lube that isn't graphite or teflon will harden at some temp, is there grease in the mechanism?
Maybe try a hair dryer or a desk lamp to gently warm it. All those little metal parts are going to be awful brittle and grumpy
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
Daughter left a little water in her car yesterday, in Texas
From my experience it is usually moisture frozen around the small shaft that goes through the handle and pushes the latch. Green arrows point to areas that freeze together.
Spraying WD40 in can help as can warming the button with a propane torch. (But not both!) Torch on low just to warm not to hot. If it's too hot to touch its too hot. When the shaft gets rusty like in the 2nd photo they attract moisture.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Roadtrip!
I just give them a smack with the palm of my hand. Sometimes you have to hit them kind of hard. Do it 6 months out of the year up here seems like...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I used to hit mine but not anymore. I learned (The hard way) about how weak the tabs that hold the button in place are. If the shaft is frozen the force of the hitting the button is transferred to the tabs. I've had to repair 2 handles on mine.
See links for more information on broken handles. http://67-72chevytrucks.com/vboard/s...d.php?t=693760 http://67-72chevytrucks.com/vboard/s...d.php?t=382093 http://67-72chevytrucks.com/vboard/s...d.php?t=770366
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 01-17-2024 at 05:47 PM. Reason: -4 grammer. |
Thanks guys for reinforcing my theory that hitting it might break something internal. The truck is parked away from power and buried in snow again, been snowing off and on since Saturday. I think I will just hold off until it gets at least into the mid thirties before I try again….appreciate the input.
At the body shop.
Alcohol should melt it
" That didnt make it any newer " " Dont antique the equipment " |
![]() Join Date: Apr 2016
When I (rarely) get stuff frozen on the truck, I go in the house and get a 1.5 quart jug and fill it with warm water from the faucet and slowly pour it on the frozen item. Water is nothing that wouldn't get on the truck anyway, so it won't hurt anything. I most recently had to do that when my gas cap was frozen and I couldn't add gas.
![]() Join Date: May 2010
I can't add to the comments already provided other than I think the picture you posted is gorgeous.
Jim |
Thanks First ! We have been off grid for the last thirty years. More elk and deer than neighbors. The temperature has risen to 28 this morning so I am going to attempt to get a door open. I need to get the lead side battery post out of the glove box so I can try to jump my diesel tractor. We are trapped because of the drifting snow blocking our driveway. Wish me luck.
Good luck and be safe! To bad all those 4 legged neighbors won't help shovel the snow!
![]() I don't know how far south and east of me you are but I've seen some single digit temps on the weather reports this week. With the wind I'd bet the wind chill factor is below zero.
#13 | |
![]() Seriously I thought the same thing when I first dropped in. Like a post card.
#14 | |
8613171 |
| Bookmarks |
