01-22-2024, 12:18 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Where can I buy this fuel line.
So I removed the bench seat to do some floor work and noticed this dent in the fuel line. What does this line do and where would I buy? Thanks.
01-22-2024, 03:32 PM | #2 |
425hp409
Re: Where can I buy this fuel line.
That is a vapor/vent line. Leave it as is or cut out the bent part and install a rubber fuel hose for a patch.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
01-22-2024, 04:04 PM | #3 |
If you can't locate, or even if you can, why not fit a patch with 2 brass compression coupler fittings. It's not high pressure so you don't need to flair. If you have my luck, the tube is probably 5/16 and a PITA to find.
01-22-2024, 04:43 PM | #4 |
If you are looking to keep it original, or as close as you can, cut it right in the wounded area, straighten with a brass hammer and punches, and braze after fixing the dent.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
01-22-2024, 05:29 PM | #5 |
Who Changed This?
I wouldn't mess with it, as only vapors should be in it. There's a large enough cross section for vapors.
01-22-2024, 06:43 PM | #6 |
You can get a 6" double flare extension bend a 90 radius in the extension. Then cut and flare the existing line to fit the 90. Else, you're into it for fabricating a whole new line; Which is no big deal, you have a template with all the bend already.
j
White K20 |
01-22-2024, 08:50 PM | #7 |
01-22-2024, 07:09 PM | #8 |
68 C10 Longbed
