01-23-2024, 02:13 PM | #1 |
High hump to low hump pan
I have searched the internet trying to find any one out there making a bolt in low hump floor pan like you would have in a 2 wd. truck that are part of the one pcs. floor.
I know that they were only a bolt in a high hump version but I thought maybe some one made the conversion the other way so you could use it to go from a high hump to the flat floor. I was trying not to cut a good cab up or a whole replacement floor to make one myself, any information is appreciated thanks Jay
Jay Snyder Leechburg, PA (Northeast of Pittsburgh) 72 Chevy Cheyenne 4x4 camper special #matching '71 Chevy Dually 4x4 '69 Chevy Pro Street swb. '72 Chevy camper special 4x4 402 v8 (not factory) just cool. (truck puller) 70 Chevy swb 400 v8 400 turbo 72 Chevy suburban 4x4, 396 4spd. 68 Chevy shortbed 50th Anv. 327. 72 Chevy 2 wd. Blazer 69 Chevy swb 4x4 327 4spd. 58 Chevy Apache 4x4 swb. 71 Chevy CREW CAB swb 4x4 396 4spd. (just finished) WE BUY AND SALE TRUCKS AND PARTS |
01-23-2024, 03:29 PM | #2 |
Re: High hump to low hump pan
There's no bolt in low-hump on the market that I'm aware of. Everybody is typically needing more clearance, not less, hence the high humps being made
1985 GMC Sierra Classic Chopped down wrongbed Cammed LH6 5.3/T56/3.90 Walker Tuned 5/8 drop US Mags |
01-23-2024, 03:36 PM | #3 |
Yeah I've never seen an aftermarket one. A buddy and I cut one out of a cab to use, though: it was not hard.
Don't feel bad, there are lots of cabs getting crushed and you might as well get a trans hump out of one of them. The nice thing about them is that they are usually so soaked in grease that they are rust-free!
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
01-23-2024, 05:34 PM | #4 |
I've got a low hump listed for sale. You'd have to weld it in though.
https://67-72chevytrucks.com/vboard/...d.php?t=847910 |
01-23-2024, 06:14 PM | #5 |
Junior Member
If you could locate a dented up hood that would be perfect for the floor pan.
Next I would try and find a hi hump truck and make a template for the size and bolt locations. Weld in the nuts required and rust encapsulate the underneath. A roll of seam caulk and you will be looking factory Just my humble solution I would do Mike |
01-24-2024, 09:58 AM | #6 |
thank you all very much. I have 3 cabs here at my place in western Pa. and they are really hard to get in half decent shape. I would be interested in the pan that is for sale. I surely do appreciate all of the comments and help that I have received over the years. Thanks Jay
01-24-2024, 01:44 PM | #7 |
Easy enough to make one. years ago I wanted access into that area so I cut out the original floor following the factory stamped beads. Added a 1" flange around that. I used some captured body nuts and bolted the original piece back in.
03-03-2024, 10:19 PM | #8 |
I had a fella on here that wanted a high hump. I traded him for a cut out of a junk cab floor. I have a body lift so the low hump is low enough. I had him cut it out larger than needed and just cut to size and drilled holes. Works great.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-04-2024, 01:05 PM | #9 |
The one i bought on here worked out really well for me also. thanks for the comment, every bit helps
03-05-2024, 11:03 AM | #10 |
I cut the low hump out of a floor a buddy bought for the rockers. I then took the high hump and traced the hole layout and edges onto the low hump and trimmed it up and drilled the holes so it will bolt down like if the factory did it. then seam sealed it up before putting the carpet down.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
