Old 01-27-2024, 08:16 PM   #1
hart11b
hart11b's Avatar
Best way to clean crusty parts
My boys and I are doing the entire front end on our 1969 C20. We have it all taken apart, but the control arms I am reusing are extremely crusty. Lots of grease/dirt built up on them from 55 years of farm.
I’ve gotten rid of most of the big stuff with a brush and a hammer/chisel. I planned on soaking them for a few days in a degreaser concoction and then taking them to get blasted and then repaint.
Is there a better way to do it? If painting, just use a chassis black enamel after primer?
hart11b is offline   Reply With Quote
Old 01-27-2024, 08:22 PM   #2
68Gold/white
Re: Best way to clean crusty parts
Diesel will dissolve all the greasy cruddy stuff. If I have a small area, I use WD40, its about the same stuff. To get any thin residue left on, Simple green.
68Gold/white is offline   Reply With Quote
Old 01-27-2024, 08:47 PM   #3
Getter-Done
Getter-Done's Avatar
The Mean Green from DG is pretty good.
Link: https://www.dollargeneral.com/p/mean...n/720547001017
The early bird gets the worm,
84 Chevy K-20
Old 01-27-2024, 09:45 PM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
I've been using Purple Power(since seeing a video demonstrating it working better than Super Clean) for the reasonable stuff.
For the "poor man's undercoating" where the oils and grit have caked up, I've been scraping the worst of it off and using O'Reilly generic engine cleaner. I've stopped using brushes until the sticky crap is gone because it just gunks them up
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is online now   Reply With Quote
Old 01-27-2024, 10:42 PM   #5
novaX522
I used brake clean for grease and gunk. I used a 4” grinder with a wire wheel to get the crusty stuff off.
novaX522 is offline   Reply With Quote
Old 01-27-2024, 10:55 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Best way to clean crusty parts
oven cleaner from the local dollar store works well on gunky stuff
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 01-28-2024, 08:41 AM   #7
hart11b
hart11b's Avatar
Thanks for the replies. We’ll get to work with a few of the techniques and post the results when complete.
Old 01-28-2024, 11:09 AM   #8
72c20customcamper
72c20customcamper's Avatar
Lots of scrapping first . Then EZ off oven cleaner .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 01-28-2024, 12:25 PM   #9
raggedjim
raggedjim's Avatar
If they are off I soak them in one of the degreasers listed for a couple days then load them up and take them to the carwash. The guy who owns it is a buddy of mine and he said it doesn't bother him, but he hates the horse guys who clean out their trailers there!
raggedjim is offline   Reply With Quote
Old 01-28-2024, 12:38 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Bilge cleaner
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-28-2024, 01:21 PM   #11
Dollar Store oven cleaner and my pressure washer is how I do most super greaser things like the frame/suspension. If I don't have the oven cleaner or after it, I use the purple power stuff.
Old 01-29-2024, 02:07 PM   #12
Shifty One
Shifty One's Avatar
1 to 9 ratio of molasses to water. Don't leave softer metal parts too long, it will eat them.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-29-2024, 06:01 PM   #13
Chevy nutcase
Chevy nutcase's Avatar
Molasses? 🤔 please elaborate
Chevy nutcase is offline   Reply With Quote
Old 01-29-2024, 06:13 PM   #14
MySons68C20
MySons68C20's Avatar
https://www.google.com/search?q=mola...t=gws-wiz-serp
MySons68C20 is offline   Reply With Quote
Old 01-29-2024, 07:21 PM   #15
Rust_never_sleeps
Molasses has citric acid(as a preservative?) so it can work on rust, but IDK if it's any good on grease.
Code:
            __
     ______|__]\____
Old 01-29-2024, 07:44 PM   #16
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Spray degreeser, let it soak than head over to a self serve car wash and use the high pressure washer.
Or take the parts to a mashing shop to have the parts cleaned. That's what I did when I was restoring my '87 Chevy, I took the parts to a machine shop, had them remove any ball joints or bushings, they soaked the parts overnight, put the parts through a cleaning machine, I took the parts home to get painted, than back to the shop to have any ball joints or bushings pressed back in.
desert-rat is offline   Reply With Quote
