02-21-2024, 05:32 PM | #1 |
Is there a difference between C10 and C20/C30 Control Arms?
Hey guys,
Is there a difference between the C10 control arms and the C20/C30 control arms? How about a difference between the heavy duty front brakes and the regular front brakes? The reason I ask is because several years ago, I bought some 3" drop spindles to put on my C10 1/2 ton. Like an idiot I didn't heed the warnings about getting the correct ones, and I accidently got the ones for heavy duty front brakes. So I ended up just putting heavy duty calipers, hoses, bearings, rotors etc. I also cut a coil off the springs. When I got it all back together I noticed the camber was way off. The tops of the wheels were leaned way in. At the time I assumed that this was because I cut the springs. Fast forward like 5+ years, Im getting close to getting it back on the road. But before I jump back into this project, Im just curious whether I should expect to have to replace the A-arms too, or if I should just expect to shim it out. |
02-22-2024, 11:48 AM | #2 |
Re: Is there a difference between C10 and C20/C30 Control Arms?
Yep, the C20/30 arms are different from the C10s. The difference in HD and regular brakes on the C10s are 1.25" rotors vs 1.00" with corresponding calipers.
1985 GMC Sierra Classic Chopped down wrongbed Cammed LH6 5.3/T56/3.90 Walker Tuned 5/8 drop US Mags |
02-22-2024, 05:46 PM | #3 |
73-87 C10 arms came w/'car style' rubber bushings to help improve the ride quality.
C10's were offered with light duty 1" brakes starting w/the Metric years (I believe 81 was the start) on the bare bones trucks. The previous 'standard' 1.25" brakes were called the 'HD' option @ that same time. C20/30's utilize different/bigger brake set-ups, heavier duty BJ's, & have the earlier generations heavier-duty steel threaded bushings.
02-23-2024, 06:52 AM | #4 |
Thanks guys,
This answers my question. Sounds like even though I swapped over to HD spindles drop spindles (BEL-3100), I shouldn't have a problem correcting the camber issue on my C10. I was afraid that I accidently put 3/4 ton spindles/calipers/etc on and would not be able to fix the alignment. Its been a few years since I worked on my truck, so I'm getting back in the swing of things. |
