Old 02-22-2024, 10:28 AM   #1
Ricks1971
Ricks1971's Avatar
Cleaning the old glue off the door moldings help
I am in the process in replacing both side door moldings and I have removed the old moldings and I need help in getting the old glue off the doors without damaging the paint. thanks Rick
Ricks1971 is offline   Reply With Quote
Old 02-22-2024, 10:46 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Cleaning the old glue off the door moldings help
I've used WD-40 with good results. Spray on and let soak for a few minutes. Clean after adhesive removed with Dawn dish soap. Goo-gone should work well too. Do not use gasoline or paint thinner.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-22-2024, 10:59 AM   #3
Ricks1971
Ricks1971's Avatar
Thanks I will try this
Old 02-22-2024, 11:15 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Yep, WD-40 and wash. The oil will take it off so easily. I wouldn't bother with goo gone, ever. I find it worthless. Edit: Heat it up with a blow drier.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-22-2024, 11:35 AM   #5
PbFut
Depends on what was used. The glue on my 72 was stupid hard in some areas. Not likely a weather stripping glue. Nothing would soften it. I was painting so not an issue to wire wheel it being careful with the seam areas. If I was just changing weather stripping, I would have gotten the soft stuff off with WD40, or goof off, and left the hard glue in place and resealed with correct glue if needed. If you have some rust showing anywhere under the stripping and not painting, dab some converter on the spots just to slow things down. Certainly not a permanent solution but buys time and reduces forward progress of the rust. Most converters turn the rust and bare metal to a mat black color.
PbFut is offline   Reply With Quote
Old 02-22-2024, 11:52 AM   #6
michael bustamante
michael bustamante's Avatar
goof off....
1967custom
michael bustamante is offline   Reply With Quote
Old 02-22-2024, 05:14 PM   #7
LS short box
You could try a 3M "eraser" wheel. Goes in a drill. Works well for taking decals off. Taking off double sided tape left on the body after removing the body moldings.
We use it all the time at the body shop I help at a couple days a week.
Old 02-24-2024, 08:28 AM   #8
don t. - 72gmc
Cuz I have it on hand, I use PBlaster. I also use a piece of paper towel, sprayed w/Pb, and placed on the item to be removed. Helps to let it soak in. Can reapply PB as needed.
HTH...Don.
don t. - 72gmc is offline   Reply With Quote
