"something witty here"
6.2 fuel sending unit advice
I have a cummins swapped k30 crew cab and recently my tank started leaking so I got a new tank and a diesel sending unit for the driver side. The problem I have is the new diesel sending unit has a ground wire attached to nothing in it and I have no idea where it goes because the old gas unit does not have the same wiring. Anyone have any idea where it should go? I dont like the idea of a wire just lose in the tank. and info would be greatly appreciated!
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
Re: 6.2 fuel sending unit advice
On my diesel 85 K30 the sending unit ground wire passes through the frame right around the back of the cab and attached to a stud on the inside of the c-channel there. Probably anywhere you can ground it to the frame would be sufficient.
![]() Join Date: Mar 2003
Looks like an optional power lead for an internal pump, but I would drill a small hole in that flat bracket and put an electrical eyelet on it, solder it, and bolt it on.
N9PHW
What year did you specify for the new sender? 82-83 had the water in fuel sender in the fuel tank when they used the spin on fuel filters and would account for the internal wire.
"I got it one piece at a time and it didn't cost me a dime..." |
#5 | |
Moderator
![]() Join Date: Oct 2008
I wondered what the reasoning for going to that leaky abomination of the Stanadyne 80 box filter.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
N9PHW
They used two spin on filters for 82-83. One on the firewall, one on the back of the intake.
#7 | |
Moderator
My '80s VW diesels had spin on filters and they just worked. The Stanadyne 80 was an obnoxious leaky abomination.
