01-12-2004, 01:30 AM | #1 |
Embrace the Redneck
Rear end ID!?
How do you tell what kind of Rear end you have on your pickup? I've got a 68 c10 w/ the orginal rear in it. What is it?
'01 Camaro Son, you just can't get there from here... |
01-12-2004, 01:32 AM | #2 |
99% sure it is a corporate 12 bolt...should be easy to ID by the 12 bolts holding the diff cover on. If it doesn't have 12 bolts, then it is something else...and we can probably tell you what that is, also.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-12-2004, 01:36 AM | #3 |
Embrace the Redneck
Corporate 12 bolt?? what does that mean??
01-12-2004, 01:51 AM | #4 | |
01-12-2004, 01:58 AM | #5 |
Embrace the Redneck
Is it a posi rear?
01-12-2004, 02:01 AM | #6 |
its all about the +6 inches
That would be an option installed inside your rear....could go either way, but probably not.
Go out and do a burn out. If you leave one mark, then you either have no posi, or a burned out posi. If you have 2 black marks in the street from one burn out, then you are in luck. |
01-12-2004, 02:01 AM | #7 |
You will have to pull the rear cover off to find that out. Some were posi-trac and some were an open diff. Is your glove box tag intact?
01-12-2004, 02:04 AM | #8 |
Embrace the Redneck
that was painted over by the last fool who owned it and ran Penzoil (CRAP!!) in it. I did a, well i tried to do a burn the other day and I left 2, or so i think, I'll try again.
You know, a 6 cyl w/ a 3 on the tree can only do so much! Amen?
01-12-2004, 02:06 AM | #9 |
"Go out and do a burn out"
250 plus 3 speed= gotta learn how to type faster |
01-12-2004, 02:08 AM | #10 |
Embrace the Redneck
kwmech what does it equal??? come on??
01-12-2004, 02:14 AM | #11 |
I was being sarcastic
01-12-2004, 02:14 AM | #12 |
just rev it up a little higher. Onless you have a real sick engine or a slipping clutch you should be able to lay a good 10 foot patch.
Onless you have some 275/60's out back anyways. |
01-12-2004, 02:18 AM | #13 |
Embrace the Redneck
nope, just 235/75/15
