03-07-2024, 09:55 PM | #1 |
Jegs mini starter question
I'm in the last stages of a 350 taking the place of my 250 in my 66 c10 and it's come to the starter. I was considering the bellhousing mounted one from my 250 as it never gave me any trouble but at this point everything else is new and header clearance is always a concern. I'm getting the jegs mini starter and in the description it says that vehicles originally equipped with points need a diode to use this starter. Im no electrical wizard who's wondering why this is necessary or if it's necessary as Jegs says "MAY REQUIRE" . It's only 10 bucks so no biggie there. Love to hear insight on the matter
03-08-2024, 08:30 PM | #2 |
Re: Jegs mini starter question
Well if your truck is equipped requiring the R terminal you could use that diode kit. That may apply if you have a points distributor. You don't need to attach a wire at the R terminal if you have an HEI distributor that has been wired with a regular wire instead of the resistor wire that was going to the external coil back when your truck had a points distributor. Or you don't need to attach a wire at the R terminal if you have a points distributor with a coil that has been wired with a regular wire instead of the resistor wire because you have changed your coil to one that runs on the full 12V such as the one dmb mentioned in this other thread. https://67-72chevytrucks.com/vboard/...83#post9285783
So, do you use the R terminal, or do you need to use the R terminal on that new engine? I think the way they said the diode is for "GM vehicles originally equipped with breaker point ignitions" might be better worded something like "GM vehicles currently equipped with breaker point ignitions and that use the R terminal on the starter to bypass the resistor wire leading to the coil". |
03-08-2024, 09:45 PM | #3 | |
As for it fitting the cast bell I Don't see why it wouldn't. it's a block mounted starter with only the starter gear occasionally visiting the inside of the bellhousing. what I know wont fit is the very common starters from the 70s and 80s. the nose cone on them absolutely wont fit in there. |
03-08-2024, 10:07 PM | #4 | |
03-08-2024, 10:58 PM | #5 | |
03-08-2024, 09:08 PM | #6 |
Active Member
Will that starter work with the cast iron bellhousing??
Old dogs and children and watermelon wine |
03-08-2024, 11:25 PM | #7 |
I'm sorry I may have been mistaken because I do not find resistor wire or ballast resistor mentioned on most of the 60-66 wiring diagrams I find. So please take what I say with a grain of salt. This diagram does appear to have a resistor wire, it is marked 20 W/OR/PPL, it would be a cloth covered wire and most likely faded to white after all these years:
https://67-72chevytrucks.com/vboard/...75#post2958975 If you think you have a white cloth covered wire going to your HEI that is most likely the resistor wire and should be replaced with a 14 or 12 gauge wire and you would not need the yellow wire going to the starter R terminal. Follow the wire and see what color it is and where it goes. There are some setups where it is common to go through a ballast resistor and may be a pink wire. For HEI you don't need a ballast resistor or resistor wire. You may get better answers from folks that know more than me by posting in the electrical section of the forum. |
03-08-2024, 11:45 PM | #8 |
Since you're running an HEI in a 60-66 truck, you should definitely replace that resistor wire. It's only on the engine side.
What I did was remove the resistor wire from the under hood harness, remove the terminal end, attach terminal to new power wire that doesn't have any resistors, then reinstalled to the engine harness and ran the full 12 volts to the HEI. Since you have the HEI already in place, no need to buy that resistor thing for that mini starter because you won't need the stock wire to the R terminal. I pulled that wire when I pulled the points out, but I did keep it intact if I ever had a need to swap back to the points dizzy
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-11-2024, 03:37 PM | #9 |
The ACDelco PMGR starters are better and cheaper than the mini starters that have that big old chunk of aluminum attached to them. Don't know if they nor the Jegs mini starter will work with the factory cast iron bellhousing though.
03-11-2024, 05:45 PM | #10 | |
66 GMC Suburban Custom 66 Chevy K10 Suburban |
03-12-2024, 07:39 PM | #11 | |
