Old 03-15-2024, 11:21 AM   #1
Tony71c10
73-87 Frame Help
I have a 84 c10 2wd swb truck that just encountered some frame damage. I guy is giving me a free 78 frame if I want it. Question is can I used this 78 frame with the 84 body. Read that the front end needs to be trimmed but is there any other obstacles one my encounter. I'm hoping it's a direct swap from one frame to the other. Any help is always appreciated.
Tony71c10 is offline   Reply With Quote
Old 03-16-2024, 02:16 AM   #2
wazzabie
Re: 73-87 Frame Help
Why not take your frame to a shop to get your realigned?
wazzabie is offline   Reply With Quote
Old 03-16-2024, 06:28 AM   #3
Impact02
Impact02's Avatar
73-80 frame is different at the front for bumper. Body will fit fine. If you want to use the 81-87 style bumper that will be your biggest work around.
69 Camaro Z/28 72 c-10 454 th 350 86 k 30 454 4 speed 96 k 1500 350 vortec
Impact02 is offline   Reply With Quote
Old 03-17-2024, 07:59 AM   #4
Pontiac1976
Pontiac1976's Avatar
Impact02
and the E-Brake cables have to use 73-80 unless you take your cut your brackets off the 84 frame and reweld or bolt them on the 73-80 frame. The 73-80 frame is heavier. The trucks 73-79 have std bolt & holes nuts, as the trucks 80-87 have SAE and Metric mix.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-18-2024, 10:07 AM   #5
1971Stepside
Almost Satisfied
1971Stepside's Avatar
You don't need to cut the front of the frame. Cut the bumper brackets instead. The cab mounts are different as well. You can swap the perches or swap the rubbers. E-brake was different on my 85 versus the 78 frame I am using, but I have seen some early 80's that are using the same E-brake setup as the older models. I just put an 85 body on a 78 frame. Let me know if you have questions
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 03-19-2024, 07:43 AM   #6
Tony71c10
Thanks to all for all information provided.
Old 03-19-2024, 09:00 AM   #7
SCOTI
SCOTI's Avatar
One thing not mentioned is the VIN will be different on the frame vs the body if you go that route. Document the frames VIN just in case it ever comes up (theft).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-19-2024, 04:11 PM   #8
PowerdbyChevy79
PowerdbyChevy79's Avatar
Your body mounts need to match the frame.. not the Cab... front frame horns will need to be reworked to fit the newer style bumper... also the E-brake mount is different
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 03-19-2024, 05:45 PM   #9
1971Stepside
Almost Satisfied
You do not have to cut the front frame horns! Cut the brackets.
Old 03-20-2024, 11:24 AM   #10
PowerdbyChevy79
good info...
1966 C10 "Mary"
