Old 03-18-2024, 03:37 PM   #1
68isgreat
Coolant hose routing question
Hi guys, I have a 68 shorty stepside I've done a frame off on, and I'm installing a 1990 350 tbi motor in it with about 90k miles supposedly, and a newly rebuilt (supposedly) 700r4 with less than 1k miles on it. This was a farm truck with a six banger, so I'm starting from scratch. I just got a new painless harness and will be installing a rear efi tank soon. Right now, I have the coolant hose outlet at the rear of the intake manifold capped off, as well as the one from the top of my radiator, which is from a square body, so it has the two upper inlet hoses. Before I hook the hoses up to the heater core (the cab is still off the frame), I just want to see if it runs ok. Can I hook up the rear manifold outlet hose to the upper right outlet hose on the radiator temporarily just to see how it runs? I don't want it to overheat. Just want to make sure that's the correct coolant flow, from the rear outlet (which would normally go to the heater core inlet) and back to the radiator, which would flow down to the lower radiator hose and up to the water pump. I can post a pic if necessary.
Thanks!
68isgreat is offline   Reply With Quote
Old 03-19-2024, 01:52 PM   #2
MikeB
MikeB's Avatar
Re: Coolant hose routing question
Not sure what you mean about a coolant hose outlet at the rear of the intake manifold. How about some photos?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 03-19-2024, 03:23 PM   #3
54blackhornet
54blackhornet's Avatar
Most of the older engines had the outlet on the front passenger side of the intake. I have mine looped because the heater core has a leak. Intake to water pump, works fine.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-19-2024, 06:17 PM   #4
weq92f
weq92f's Avatar
You should be able to run it for a short time with no coolant without causing any damage. If you just wanna make sure it'll start and run, go for it...don't mess with the cooling system at all.
Just remove the belt(s) and fire it up.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-01-2024, 12:40 PM   #5
68isgreat
-klb
Thanks! I might do this.
Old 03-19-2024, 09:30 PM   #6
chewychevy67
On tbi 90's engines there is a coolant line from the rear of the intake by the dizzy hole. I think this is what the op is referring to.
chewychevy67 is online now   Reply With Quote
Old 04-01-2024, 12:42 PM   #7
68isgreat
Yes that is correct. I have that outlet capped and was just wondering if I should loop it back to the top passenger side hose on the radiator, which is the same size hose. Not sure if the water needs to flow in a loop like that, or if it can remain capped until I get the heater hooked up?
Also, my tbi doesn't have the vacuum tube coming out the drivers side front that loops back towards the firewall as shown in the pic above. Do I need to have that hooked up, or can I just cap it off? Someone removed the EGR system and capped it off on the manifold. I'm not even sure what that tube is supposed to hook up to? I'll try to post some pics soon. I just ordered a bed mount efi gas tank, so I'll be firing it up here in the next few weeks.
