Step side wood bed question
The 64 step side i just bought has a piece of checker plate instead of wood. All the cross frame is there ,We are planning to put wood kit back in. Question is on the box sides is angle iron (think original ) .Does the narrow outside wood sit on this then the polished chrome angle goes on top or does that need to be removed ?Have done fleet side but never step side .No holes in angle that is there now. Thanks in advance. Do not have pics of box at this moment.
![]() Join Date: Dec 2009
Re: Step side wood bed question
I am no Help on your Question about the angle.
Here's a TTT for you and a link to GMC Paul's info on Bed wood Dimensions. Link: https://gmcpauls.com/47-72_BedWood_Info.htm
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() ![]() ![]() Join Date: Jan 2018
Can you get us a picture of what you're working with? Just from the initial read, with the steel floor being installed previously, could be some not stock stuff going on as well.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
I believe there is only shaped angle on the bed sides that slip over the side boards. The boards are sandwiched between that and the cross sills.
╚═ wood ═══════
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Moderator
![]() Join Date: Dec 2012
SkinnyG is correct.
Will try get a picture. The angle is on the box sides. My question is does that come off when you use the chrome box strips ? Some on here show a chrome angle along the side others show black steel.
The bed on my truck was all original, and I had to drill out the welds holding what was left of the angle strips.
I chose to buy just plain repop steel strips, as I knew I would be spraying Raptor on all the bed metal. I imagine you'd have to bolt the chrome ones on.
Moderator
Mine's a fleetside so no separate strips. Some of mine were rusted, so I made new strips and screwed them in place when I rebuilt the bed. Worked perfectly.
If there are no holes in it. then it is probably not original. It should bolt together just like the fleetside only without the wheel wells. When you say chrome strips are you talking about the ones that they sell to cover the old strips or the kind that are made to be welded onto the sides of the box? There are two types. These trucks never came with the type that cover the old strips. Is the L shaped peace that you are talking about have the same little humps along the edge like the center strips do? If they don't then they are not original.
Ok so wood goes goes under the wheel wells on a fleet side .Does wood go under the angle or sit on it..The chrome strips that go over the angle do you remove the original or go over it. Thanks
The wool goes in between the cross sills and under the angle.
![]() Join Date: Apr 2010
The chrome or stainless angles are just covers. The original angels are spot welded to the bed sides and these sit on top. The wood is under both pieces.
1951 Truck, LS1/4L60 1964 Suburban, current project |
Thanks twed I may need to check mine further .The checker plate was on top of the angle and the cross ribs are welded to the box sides.
It sounds like there were some modifications done in order to install that diamond plate.
