Painting aluminum
I am in the process of rebuilding my egnine and I not sure how to prep and paint my aluminum pieces: valve covers, tappet cover, oil pan. I've soaked them in Simple Green and hit them with brakekleen. The grease and grim came off but there's a lot of stains on them. Should this be sanded off or will the primer conceal it? Do I need to do anything else?
Thanks for any help. Joe |
#2 | |
Re: Painting aluminum
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
I had some aluminum engine brackets blasted. The company I use is really good and just cleaned them up to look as close to stock as possible. I'll probably run them as is without coating them with anything, but could easily paint them now.
![]() Join Date: Nov 2013
I've painted a few smaller parts by blasting with aluminum oxide media, acid etching with aluminum brightener, the immediately priming with either self-etching or epoxy primer.
I think the hardest part of painting an entire aluminum engine would be getting all the oxidation off and getting it clean enough for the paint to stick and stay on over a long period of time. I debated painting my aluminum LS but ultimately just cleaned it and left it as is, after all it's not going to rust....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
For driver quality, sand and scuff them, as best you can. Clean with thinner and use a quality rattle can. For show quality or long term durability. Sand blast, clean with thinner, epoxy, prime. Then top coat with a 2K single stage or base/clear.
I've had very very good luck with StarBrite aluminum cleaner. It's made for the marine industry, specifically cleaning aluminum pontoons.
https://www.amazon.com/STAR-BRITE-Ul...s%2C120&sr=8-5 |
![]() Join Date: Feb 2004
I do what 62c30 and A1971 Blazer do. Clean them then lightly sand blast. You can use a self-etching primer if you want and they will hold paint a long time.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 05-06-2024 at 08:23 AM. Reason: words |
