Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-23-2024, 12:17 PM   #1
kaycee
kaycee's Avatar
Power window Buick
At witts end here on my 02 Buck Century, drivers side rear window wont roll down all other windows work . Wont roll down from master switch (front drivers side)works all other windows .Got new motor / regulator swapped it out same problem ,swapped door switch out to other side same thing no roll up on drivers rear. allso old and new motors swapped over and still wont work on drivers side. Have swapped relays around and have power all the way to motor WTH am I missing here
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 03-23-2024, 12:36 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Power window Buick
Wires sometimes break where they run through the door.
They may not appear to be broken because the insulation is still intact.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 03-23-2024, 12:42 PM   #3
kaycee
kaycee's Avatar
I got power all the way to motor on the old and new motor sand they both check out with test light.
2005 FXDWG stage3
63 IMPALA 327
Old 03-23-2024, 02:01 PM   #4
Getter-Done
Have you plugged the old regulator in (Outside of the door)?
Just to see what happens.
84 Chevy K-20
Old 03-23-2024, 04:00 PM   #5
kaycee
kaycee's Avatar
Yes it rolls up and not down on both new and old reg /mmotor will go up and down on pass. Side
2005 FXDWG stage3
63 IMPALA 327
Old 03-23-2024, 04:48 PM   #6
Getter-Done
I found a wiring diagram online.
That is the best picture I can get.
So you have both up and down wires that have 12 volts?
84 Chevy K-20
