04-02-2024, 11:48 PM | #1 |
What Brand of Stud Welder to buy?
Hey Gents,
I'm getting into some minor body dent repairs on the truck and am looking to buy a Stud Welder. Amazon sells Vevor brand but it seems to have not so good reviews. Is there another company that makes these that aren't going to break the bank but are of decent quality that you'd recommend? Cheers!
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
04-03-2024, 01:24 AM | #2 |
Re: What Brand of Stud Welder to buy?
Interested in answers to this one too.
04-03-2024, 08:28 AM | #3 |
hi, my girl friend bought me a harbor freight stud gun to pull out a dent in my oil pan that was touching the crank. worked well and got the dent out without putting a hole in it. BROWN 70
04-03-2024, 04:25 PM | #4 |
I bought a Harbor Freight stud puller gun and puller. Worked well for a hobby project like my 68 C10.
But if I was working in a production shop I would buy a slide hammer with collet like Snap On has. The Snap On slide hammer has a collet the you tighten more or less like a hand drill. |
04-03-2024, 06:00 PM | #5 | |
It works fine for how cheap it is. Definitely hobby Grade though. The slide hammer leaves a lot to be desired, the way it grips the stud is not great, kind of fiddly . Years ago in 1987 when I was starting to buy tools I bought a very nice stud gun , professional grade, a Bluepoint if memory serves. It was expensive at almost $600 then. It came in a nice case and had attachments like a shrinking tip, but the best thing was the slide hammer was like LS short box described tightening similar to a cordless drill chuck , much better and faster for production use. Wish I still had it, never sell your tools or guns if you can help it…..
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
04-04-2024, 01:34 AM | #6 |
I also have a Harbor freight stud gun but didn’t like the slide hammer. I welded vise grips to another cheap one I have and also made a stud lever which allows me to apply pressure to the dent while hammering down the high perimeter. Something you can’t easily do with a slide hammer.
1972 GMC K2500 Super Custom Matt |
04-04-2024, 06:11 AM | #7 |
Is this the same one from Amazon?
You also get a Discount if you order direct from Vevor. Link: https://www.vevor.com/stud-welder-c_...p_010633845352
04-04-2024, 08:58 AM | #8 |
I've got an H&S Autoshot I picked up at the pawn shop. It is great.
I also have the Harbor freight one but I've never used it. Some one told me the Harbor Freight ones work better if you buy studs that are better grade.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
04-04-2024, 12:37 PM | #9 |
I'm cheap. I buy the studs from Harbor freight and tack them on with my tig welder and pull them with a slide hammer that i got from Eastwood.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
04-04-2024, 09:33 PM | #10 |
The vevor has several accessories the HF doesn’t. Like shrinking tips and wavy crease pullers. If I were doing it again, as a hobbyist, I’d prolly go with the vevor.
04-04-2024, 09:50 PM | #11 |
Awesome guys, looks like I'll have to give the Vevor a try to start!
04-04-2024, 10:49 PM | #12 | |
If you register you get a Discount . I have bought several things from them and all was good. A Planishing hammer was one of many things.
04-04-2024, 10:59 PM | #13 |
Register with Vevor? Was gonna buy it off of Amazon
04-04-2024, 11:08 PM | #14 |
04-04-2024, 11:14 PM | #15 |
Just added this in case it is a better deal.
Link: https://www.vevor.com/stud-welder-c_...p_010633845352 I always Compare when shopping. Hope this Helps.
