05-06-2024, 01:05 AM | #1 |
4x4 engine crossmember question
So a long story short I have a 1965 k10 project (sitting on a square body k10 frame) I need a 4x4 engine crossmember to replace my weird “horse shoe” engine mount I have currently. What I’m wondering is, does anyone make an engine crossmember for these trucks that will work or am I just going to have to pull one from a junkyard? I’ve found a few aftermarket ones but it seems like they are all for LS/LT conversions. Any help would be greatly appreciated.
05-06-2024, 03:03 PM | #2 | |
Re: 4x4 engine crossmember question
05-07-2024, 08:03 AM | #3 |
are you saying the factory frame crossmember is bent? I have a stock one if you need a replacement. otherwise, the offroad design one is a nice piece.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-10-2024, 02:37 AM | #4 |
The one I have at this moment is the “horseshoe mount” it is bolted to the frame and engine right under the harmonic balancer. And my old Bell housing is the rear motor mount. There isn’t a crossmember where the normal engine mounts mount to the side of the block. I got a different transmission and transfer case to replace the old one. Do you happen to have a link to the crossmember you are referring to?
05-10-2024, 02:55 AM | #5 |
https://67-72chevytrucks.com/vboard/...d.php?t=844603
This is a link to an earlier post about my truck |
05-10-2024, 03:24 PM | #6 | |
There’s ones for big block and LS too. |
05-10-2024, 04:49 AM | #7 |
That looks like the original frame. Squares don't have the horse shoe engine mounts. Also with the bolt on spring hangers.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
05-10-2024, 07:25 PM | #8 |
05-10-2024, 10:36 PM | #9 |
Born Psycho
we built a 63 short 4x4 for my nephew several years ago, built on a real 4x4 frame-65 if i remember correctly- and we used cross members from 72 4x4 for the engine and trans, had to drill some holes and it all bolted up without any issues. we used an SM465 205 combo with power steering and disc brake front diff. he has taken that truck all over the western U.S. hunting deer and elk without any problems. if you need help locating 67-72 cross members for the engine and/or trans I have both and i'm sure other members on here can help too. as was stated earlier, your frame is not a squarebody frame, my guess is 66 or older.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-11-2024, 01:47 AM | #10 | |
05-17-2024, 09:50 AM | #11 |
Born Psycho
Cody,
i'll give you a call tonight after work, in case i forget i p.m'd. you my number. they will be pricey to ship but i'll work on getting a price if we work out a deal, i can do $150.00 for both plus the freight.
