Old 06-14-2024, 05:03 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
WTB Door Latch Relay Mechanism (regulator)
Looking to buy LH Driver Side door handle mechanism for 71 C10. I will take both LH & RH if they are both in really good condition. I'd rather not take a chance on aftermarket
I believe these would have to be from 68-71. I know at least that '72 is a one-year only. I only need the handle mechanism.
Let me know what you have. Thanks.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 06-15-2024, 06:53 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: WTB Door Latch Relay Mechanism (regulator)
Let me check, I have several but need to see what side and what condition.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 06-15-2024, 08:48 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
This is what I have, don't know for sure if its OEM or not. Spring is good.
I also have the matched pass side also. Look the pictures over and see what you think.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-15-2024, 09:51 PM   #4
derotoreut
derotoreut's Avatar
Gary
Do you know what year these were out of? Also, would you please double check the springs closely on both LH & RH units? For some reason I was thinking that the spring wrapped around that square tab that sticks up. I can't confirm because the one good unit I have is installed in the truck.
~ Dan
Old 06-16-2024, 06:52 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
There's are correct for 68-71 but I don't know what specific yr they came out of.
It's been 40yrs of messing with these trucks and they were in a box with several others. I do have some good 72s including an NOS 72 I can compare them to.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-16-2024, 08:03 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
Here are a couple better pictures showing how the springs attached.
Both are not broken and are strong when moving the lever.
I believe there probably was more than 1 vender that supplied these to GM,
because I see subtle differences in how these are made. Maybe someone on here can helps us out as to tell if the OEM or not ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-16-2024, 05:46 PM   #7
derotoreut
derotoreut's Avatar
Thanks Gary for the close up pictures. Let me know what you want for each (driver side & pass side).
~ Dan
Old 06-17-2024, 04:31 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
I'm thinking $45 for both to your door.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 06-17-2024, 05:35 PM   #9
derotoreut
derotoreut's Avatar
Gary
OK, I think that will work. I will PM you my contact information. Please let me know how I can pay you.
~ Dan
Old 06-20-2024, 03:59 PM   #10
derotoreut
derotoreut's Avatar
Payment has been sent. Thanks Gary.
~ Dan
Old 06-21-2024, 06:16 AM   #11
CUSTOM/10
CUSTOM/10's Avatar
Ok, there boxed up and ready to go.
Gary
72 SWB 4x4
My 72 SWB Build
