06-15-2024, 01:56 AM | #1 |
What size is the distributor hold down bolt
Is it distributor hold down bolt 1/2 or 7/16?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
06-15-2024, 09:43 AM | #2 |
Junior Member
Re: What size is the distributor hold down bolt
It should be 3/8-16 with 9/16 hex head.
06-15-2024, 09:54 AM | #3 |
OEM 3/8 but various lengths, depending on distributor, clamp style, and manifold.
Always check that distributor has clearance to oil pump shaft by installing without gasket. Should sit flush on manifold, then, add your distributor gasket. |
06-15-2024, 11:49 AM | #4 |
Mine has a: (GR 5) 9/16” hex flange head bolt. The bolt threads are 3/8-16 x 9/16”, and the head is stamped “E”.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-15-2024, 12:00 PM | #5 |
70+ ( Old Skool Club )
From experience use a factory bolt and clamp as some of the aftrmarket ones are crap and will loosen and let your distributor move around.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-15-2024, 12:25 PM | #6 |
06-15-2024, 01:50 PM | #7 |
Thanks for the info. Going to pick up a set of these when I need to adjust timing etc.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
06-15-2024, 04:13 PM | #8 | |
06-15-2024, 04:23 PM | #9 |
06-15-2024, 07:15 PM | #10 | |
Thanks!
06-16-2024, 01:28 AM | #11 | |
