06-17-2024, 06:55 PM | #1 |
68 C10 throttle rod to cable
I thought there was a faq or writeup on how to convert from a throttle rod to cable but I can't find it. Can someone post it up?
Thanks!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
06-19-2024, 03:51 PM | #2 |
Re: 68 C10 throttle rod to cable
Ttt
06-19-2024, 04:50 PM | #3 |
Here are some search hits I came up with: https://67-72chevytrucks.com/vboard/...d.php?t=371099 https://67-72chevytrucks.com/vboard/...00#post1383300 https://67-72chevytrucks.com/vboard/...t=rod+to+cable EDIT: I think that second link above is what you're after. Hth -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-19-2024, 05:05 PM | #4 |
That's it! Thanks weq92f. I appreciate it
06-19-2024, 05:18 PM | #5 |
Active Member
Saved, Thanks for the links!
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
06-19-2024, 06:56 PM | #6 |
Those are some old links. Unfortunately the LFD guy stopped doing business about 15 years ago. And Rockcrawlin's last post was in 2018.
Putter's old post of 08/26/2005 has the best method. About what I did. From a '72 Chevy truck, I pulled the Gas Pedal and the plastic pivot triangular piece. I bought an aftermarket cable assembly from my local Hot Rod Shop. [I'm looking for pix, but my new laptop doesn't have the shots I wanted.] Works great.
06-19-2024, 09:43 PM | #7 |
Born Psycho
i did my 69 suburban the difficult way, i had a junk 72 cab and i cut out the section of the firewall where the pedal and cable were attached, drew a line around the 72 section onto the 69 firewall and cut it out, trimmed until the 72 piece fit perfectly and welded it back together. it was actually easier than it sounds since the front clip was off and the engine was out.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-20-2024, 01:14 PM | #8 |
Heres a link to the two that I read over before doing mine. If you get any questions let me know and I will try to help and/or I could post pics of my pedal mount and carb linkage bracket.
https://www.67-72chevytrucks.com/vbo...d.php?t=170383 https://67-72chevytrucks.com/vboard/...d.php?t=530828
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
