Hello all, I was changing my body mounts But I found that the hickey fuel tank mounts under the frame into the tub. So therefore I can't raise the rear of the tub to swap the body mounts. I believe this tank has through bolts. Is anyone familiar with The type of hardware that is on the underside of the through bolts? It appears to be a flush mount nut but uses a square head? Either way, mine are rusted on and I thought about just grinding off the heads in the tub and dropping everything down But I wanted to confirm that would actually be enough to drop the tank?
Thank you all!! |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Question How are hickey fuel tanks mounted?
I’m not certain, but maybe these tanks were mounted in a manner similar to the auxiliary pickup tanks with example hardware seen here: https://www.67-72chevytrucks.com/vbo...d.php?t=734283
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
Here are some pics i finally figured out how to share. It appears these are threaded internally and use a square drive? I tried to spray pb blaster inside which is why they look wet
![]() ![]() Join Date: Jul 2003
That sure does look like how the pickup RPO NL2 auxiliary tank was mounted..
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Awesome! Thanks I'll weld some nuts to the bottom and be gentle with it. The square holes were deforming.
| Bookmarks |
