07-13-2024, 11:48 PM | #1 |
Alignment & Coil over adjustment
Getting close to the end of finishing the 70 C 10 and have a couple of questions:
Front end is new with tubular a arms and coil overs on the front and rear. No shims on the front end and aligned by sight. Before I measure and order new wheels I would like to get the front end aligned and the ride height set. Is there any reason not to do either one of the to the truck? The truck still need the hood, grille, seat, glass and bumpers. Also I installed a 88-94 steering wheel and when tightened down, it still wobbly. It's installed a a tilt column from flaming river. I simply installed the wheel and then tightened it down. Am I missing something here? Thanks |
07-14-2024, 03:03 AM | #2 |
Re: Alignment & Coil over adjustment
Ride height is a big factor in the alignment. Camber changes as suspension moves up and down.. With that many "missing parts", the ride height will be higher than normal.
As for that wobbly steering wheel.. First thing that comes to mind is those aftermarket steering columns use GM components.. There is a spring under the T/S canceling cam that preloads the upper bearing.. If that spring is missing, the shaft will wobble... A question might be addressed to Flaming River: Is the 88 - 94 steering wheel compatible with that particular column?? |
07-14-2024, 03:28 PM | #3 |
Wait to align it until it's all assembled and full weight, ideally with half a tank of gas and your weight in the driver seat to settle the ride height as close as it'll be to when you're driving it.
If it has new springs that need to settle, set the toe to 1/16" in yourself and put some miles on it to settle the ride height/springs before having it professionally aligned. Caster or camber misalignment won't wear the tires. Good specs to shoot for since it's no longer stock and on bias plies- -.5 to -1 camber 1/16" toe in More caster than stock, hopefully the tubular arms allow for around 7 degrees. Slight stagger in L/R caster to compensate for road crown.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-16-2024, 11:26 PM | #4 |
Thanks for the advise, guess I'll wait till then.
07-17-2024, 04:37 PM | #5 |
Just got an answer from flaming river and OEM steering wheels cannot be used on their columns and they do not make an adaptor to make them work.
So I guess the steering wheel goes and I have to find one that works. Anyone using an aftermarket steering wheel on a flaming river column? |
07-17-2024, 07:52 PM | #6 |
I used these guys https://fssteeringwheels.com/
07-18-2024, 05:53 PM | #7 |
07-19-2024, 11:47 PM | #8 |
Thanks. I am going with the forever sharp steering wheel.
Talked to them and they need to know what upper shaft flaming river is using. Just waiting for an answer from flaming river to move forward. |
