Junior Member
![]() Join Date: Dec 2023
Pilot bushing removal is no fun
Recent bad noises while changing gears convinced me it was time to replace my clutch, and I decided as long as I had the drivetrain out of my '69 i6 250 3OTT, I'd replace the pilot bushing as everybody recommends because "it's only a $10 part" and you might as well do the extra few minutes of work to replace the bushing.
Well so far this dang bushing from Hades has cost me over a day of messing with it and I still don't have it out. I first bought the pilot bushing puller from Harbor Freight , but it slips out and doesn't catch it the back of the bushing. I then went to 2 different Autozones to try a different puller, but their pilot bushing puller turns out to be the same tool HF sells, under a different brand name and in a different case. So I try the "grease and bread" method from YouTube, which accomplishes nothing but getting grease and bread all over my garage floor when I try to drive it in with a socket extension and it leaks all around the tool. Then I figure I need a nice tight drive fit on the drive tool to give this the best possible chance, so I then spent an hour sanding down an oak dowel to get the snuggest possible fit to make the hydraulic method work. Still no good. So I went back to HF and bought their slide hammer/bearing puller set. This fits great but makes absolutely no progress on moving the dang bushing. I've given it 1000 hits from the slide hammer and that sucker is not going anywhere. So now between running around from store to store buying tools, and lying on my back under the truck failing to use them effectively, I've spent the better of part of two days on this problem. ![]() At this point I'm considering just giving up, leaving the old bushing, and replacing the clutch etc and getting back to driving my truck. But, I'm worried the HF bushing puller definitely scraped up the inside of the old bushing, and I don't even know what bad things might happen if I leave traces of remnant greasy bread in there... ![]() Conversely, does anybody have any pro tips on the process of chiseling these bushings out? I've read through all the threads discussing alternative ways of getting these out and clearly that's what I'm down to at this point, if I'm going to get that sucker out of there. |
Senior Moment
![]() Join Date: Mar 2002
Re: Pilot bushing removal is no fun
I’ve used the Bread method a few times with success every time. Not easy just keep at it
You might get a nice sharp bushing spitting chisel and hack away at it. Eventually you’ll get it out Good Luck
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#3 | |
That is hilarious. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
