07-29-2024, 02:44 PM | #1 |
Paint Mixing for Idiots
Ok, I am going to apologize in advance for a dumb question....but math was never a strong point with me, so please be gentle. :-)
I am getting ready to apply a seal coat of epoxy primer to my project. I am using the eastwood epoxy primer which is a 1:1 mix ratio of primer to activator.....easy enough. Now, according Eastwood, I need to reduce this by 20% with a urethane reducer in order to use it as a seal coat. How do I do this on a mixing cup? I have a boat load of these. Math sucks....plain and simple. In high school I dropped out of geometry because it was dumb and I would never ever need to know squat about angles. Well, I ended up joining the Marines and they made me a mortarman.....I guess Mr. Tuttle (geometry dick in HS) was right after all. Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
07-29-2024, 07:59 PM | #2 |
Re: Paint Mixing for Idiots
I'd go by the oz. marking on the cup... multiply however many oz you mix by .20...that'll be how much reducer you need
07-29-2024, 11:04 PM | #3 |
I total understand this.
The math thing. I almost failed Algebra in the 80's . My grandpa helped me through this issue. Stay with me on this story. I was a Knucklehead back then. (and still can be) I would ask the math teacher, Why do I need to know A+B=C ? She said it is a Formula you apply to figure things out. Years later I Totally Understand. Grandpa sat me down on the back stoop of My Grandparent's home. Then He proceeded to show me WHY. At 17 years old I didn't need that. Now years later I am a Machinist. I not only use Trigonometry. I know how to spell it. Now let's get serious. When you are getting ready to mix the paint you can give me a Call. You have to use the KISS philosophy. Just use the single digit stuff. Think of this as Money. If you have 50 cents of Primer./ 5 ounces of primer Then you add 50 cents of activator. / 5 ounces of activator This mix is = to 100% You have a 1:1 ratio. Then add 20 cents / 2 ounces of Reducer.
07-30-2024, 10:59 AM | #4 |
Yeah, math has always been a challenge for me. It can be pretty embarrassing, but for some reason I just have always had a difficult time with numbers. The only exception is fractions. I have always been good at those....maybe due to my use of a tape measure for so many years doing concrete work. Thankfully, my wife is a numbers whiz kid so she handles all that stuff.
Ok, I think that I will try to just use 20% of the total after I mix the primer and the catalyst like Greg mentioned. Thanks fellas! Clay
08-04-2024, 09:11 PM | #5 |
If you do fractions 1/5 reducer. If improves flow from the gun . I add a little MR186 to all my primers and have for many many years [Thats Omni numbers for the non PPG people] It just a splash to like I said help flow and reduce the "pebbled" look that some primers might give off depending on the primer. Good luck Happy sanding [although if your doing sealer your close to done with the sanding. Thanks for your service. Jim
08-05-2024, 08:09 AM | #6 | |
I am getting closer now. The only body work left on the truck is the tailgate now. I am hoping to get everything sanded and painted by Halloween, but we will see. :-) Clay
08-07-2024, 10:00 PM | #7 |
20 percent is a division of 5. So total ounces divided by 5. how's that for simple
08-08-2024, 09:06 AM | #8 | |
Clay
