Old 08-13-2024, 07:03 PM   #1
Island Medic
Cab replacement what will work?
I have a 1968 GMC 910 SBSS (Canada) and my cab is shot. Not only rusted but tweaked from an accident. I am looking to find a used cab that is not bent and do the metal repair. Not sure which cabs are compatible to use. I know that I can't use the 67 small window. Just not sure about others. My truck doesn't have factory AC and is an automatic. Any advise or suggestions on which ones I can use would be welcomed.
Brad
Island Medic is offline   Reply With Quote
Old 08-13-2024, 09:31 PM   #2
raggedjim
raggedjim's Avatar
Re: Cab replacement what will work?
I'm pretty sure any 68-72 cab will work from either C10 or C20 (not sure of the Canadian designations) The 67-68 had hand operated emergency brakes while 69-72 had a foot operated emergency brake. The 67-68 had a different fuse box layout. I know the earlier 67-70 had a hinged gas pedal instead of the 71-72 hung gas pedal so there is that but other differences should be minor.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 08-13-2024, 10:01 PM   #3
Island Medic
Thanks that was very helpful.
Brad
Old 08-14-2024, 10:21 AM   #4
raggedjim
raggedjim's Avatar
No problem, good luck. Good cabs are getting harder to find.
And I'm thinking the C30 cab will work too. The C40 & C50 are different at the front firewall but I believe from the dashboard back they are also the same.
Roger
'70 GMC Jimmy 2wd
Old 08-17-2024, 03:34 AM   #5
58 Special
Junior Member
The floorpans on the C40, C50, C60's cabs are different. I believe.
58 Special is offline   Reply With Quote
Old 08-17-2024, 10:05 AM   #6
raggedjim
raggedjim's Avatar
I believe you are right about this.
Roger
'70 GMC Jimmy 2wd
Old 08-14-2024, 04:08 PM   #7
LS short box
Make sure you get a cab with a clean title. Not legal to swap vin tags from one cab to the other.
Old 08-17-2024, 12:18 AM   #8
RustyPile
RustyPile's Avatar
Originally Posted by ls short box View Post
make sure you get a cab with a clean title. Not legal to swap vin tags from one cab to the other.
x 2 ^^^^^
RustyPile is offline   Reply With Quote
1968 cab 910
