08-17-2024, 03:28 AM | #1 |
New Member
Rear Outer Wheel Housing
Any suggestions on rear outer wheel housings? I need both sides. Had anyone tried to use the wheel housing section off of a inner bed panel for a fleetside? I'm not sure if the wheel opening is the same as a pick up.
08-17-2024, 03:41 AM | #2 |
Junior Member
Re: Rear Outer Wheel Housing
Almost 30 years ago, when i had my 71 GMC K10 Suburban rebuilt i supplied the body shop with a rust free fleetside box. They said it was a little different but still used it to repair all the rust. Which wasn't all that bad.
08-17-2024, 04:25 AM | #3 |
New Member
If the opening is the same, I'm thinking about getting the inner fleet side patch panel and cutting the wheel housing section off. I know there will be some fabrication work involved to attach it to inner housing.
