Fuel Pump Not Priming
My 6.0 swap (2005 DBW) has been running flawlessly for about 7 years. Recently it has on occasion failed to activate the fuel pump when turning the key on which would cause it to fail to start. I cycle the key back to off and on again, then I here the pump prime and it runs fine.
Could this be the relay going bad? The pump? |
Re: Fuel Pump Not Priming
check your grounds. I've found that most electrical gremlins that involve components working "erratically" involve a bad or loose ground.
