08-28-2024, 02:24 PM | #1 |
four headlight separate wiring for brighter lights??
some one please skool me on this, the headlights in my 91 suck. four halogen bulbs, thought I saw something about rewiring the lights for more power.
Thanks!! |
08-29-2024, 12:14 AM | #2 |
Re: four headlight separate wiring for brighter lights??
when you turn your hi-beams on, your low beams kick off. 20 mins, a relay, some wire, few female connectors for the relay and both your hi and lows stay on.
you'll need a reg 30 amp relay, #87, #85, #86 and #30 run a wire from low beam wire to #87 on relay run a wire from hi beam wire to #86 on relay run a ground from #85 on relay to a self tapping screw somewhere or to the neg on battery run a power wire from #30 on relay to pos side of batt. use an inline fuse. your low beams are on the outside and hi's are inside by the grille. highly recommend, makes a huge diff at night and you will love it |
