Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 08-28-2024, 09:33 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Bought a rough running '04 Suburban
I bought a 2004 Suburban with the 8.1 496ci engine and 4l80e, for parts. I decided to see if I could figure out the problem with it.
Scanner said code PO 306 cylinder 6 misfire. Do you think maybe this would cause the problem????
285,000 miles on it.. Should I fix it?
Leon
Old 08-28-2024, 10:01 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Bought a rough running '04 Suburban
I say Yes.
84 Chevy K-20
Old 08-28-2024, 10:45 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Yep. I love the 8.1. Torque for miles. They are one of the best truck engines GM ever built.
Tyler
57taskforce is online now   Reply With Quote
Old 08-28-2024, 11:04 PM   #4
dagnabbitt
dagnabbitt's Avatar
Little JB Weld, good to go.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 08-28-2024, 11:30 PM   #5
Boog
laying low
Boog's Avatar
Absolutely, if only to see just how far it will go.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-29-2024, 01:45 AM   #6
lil hoodlum
lil hoodlum's Avatar
Oh wow, never seen a push rod go through the rocker arm.
Wonder if it got low on oil at some point. I bet that was a dead cylinder.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is online now   Reply With Quote
Old 08-29-2024, 10:12 AM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Bought a rough running '04 Suburban
early version of GM's AFM, cylinder deactivation the hard way.
we are getting ready to replace a 5.3 in a late model GMC with AFM that deactivated #7 permanently. ordered a Jasper engine that eliminates the AFM garbage AND is legal in the peoples republic of commifornia.
throw a new rocker on yours and drive the wheels off it.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 08-29-2024, 01:33 AM   #8
RustyPile
RustyPile's Avatar
Might not be a bad idea to replace all of 'em while you're in there...
RustyPile is online now   Reply With Quote
Old 08-29-2024, 10:50 AM   #9
RustyPile
RustyPile's Avatar
As a mechanic with 35 years experience, I've seen that many times.. I've seen pushrods with the tip broken off, split rockers, pushrods that wear a hole in the rocker, broken rocker arm studs,, I even saw a pushrod go through the valve cover when the rocker arm failed, all sorts of weird things...
Old 08-29-2024, 11:12 AM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
That's a wall hanger/conversation piece.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-29-2024, 11:14 AM   #11
mongocanfly
mongocanfly's Avatar
Wow..never seen one like that
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-29-2024, 11:27 AM   #12
LockDoc
LockDoc's Avatar
Thanks guys. I have an extra rocker and push rod I will put in it and see if there are any other problems before I change all of them. I am also going to insert my inspection camera down the push rod hole and see if I can see the lifter to make sure there aren't any problems with it. I am headed out to do that now.
Leon
Old 08-29-2024, 11:27 AM   #13
57taskforce
All about them K’s
This is from the 350 in my K20 a few years ago. It was an exhaust valve so it was backfiring thru the carb pretty bad and obviously had a nasty lifter tap. Slapped another used rocker in it with the pushrod from the picture and it’s been good ever since.
Tyler
Old 08-29-2024, 11:31 AM   #14
LockDoc
LockDoc's Avatar
I hope I will be able to say the same....
I think I need to check the valve spring a little closer on that valve while I am in there too.
Leon
Old 08-29-2024, 06:17 PM   #15
kingsolver72
10/30/19
kingsolver72's Avatar
I don’t know if I’ve ever seen that scenario before but, I’m surprised that kind of thing doesn’t happen more often. There are a lot of moving parts under tension and extreme heat in an internal combustion engine.
I guess I’m stuck thinking about the old harleys that you had to tighten almost every nut at 400 miles intervals.
Leon, I’m confident that if that engine is salvageable your the man for the job.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 08-29-2024, 09:07 PM   #16
kwmech
The consensus now-a-days is that either JB Weld or spray foam will fix anything so...............
but with that many miles on it I'd personally freshen up both the eng and trans
Old 08-29-2024, 09:56 PM   #17
Boog
laying low
Boog's Avatar
Flex seal. That's the ticket!
Boog
primer is finer
Old 08-29-2024, 10:25 PM   #18
KFF 1
KFF 1's Avatar
Wow! .... Ive never seen anything like that before. You need to keep that for a conversation piece for sure!
KFF 1 is offline   Reply With Quote
Old 08-29-2024, 10:28 PM   #19
Getter-Done
Here's what I see working with the Tool and Die industry for a while.
The Stamping Die that was producing these was,
Either worn to the condition the punches and Dies needed replacing.
Or the oil flow and air blow to clear the shavings and Scrap was not in Operation,
In the picture I put arrows of things that should have been caught in the stamping process.
With that being said it almost hit 300K.
84 Chevy K-20
Old 08-30-2024, 12:04 AM   #20
LockDoc
LockDoc's Avatar
You guys crack me up....
I'm going to give it my best shot Scott.
The center of the lifter is also missing in action I was able to get the lifter out without removing the intake. I will post a picture of it in the morning.
Leon
Old 08-30-2024, 11:48 AM   #21
68Gold/white
Oh shoot!!!
I wonder if a new lifter can be installed with head and intake still on?
Next question, is what the cam lobe looks like....
68Gold/white is offline   Reply With Quote
Old 08-30-2024, 11:58 AM   #22
LockDoc
LockDoc's Avatar
Originally Posted by 68Gold/white View Post
Oh shoot!!!
Got the old broken lifter out OK. Used my flex magnet to fish out the other pieces
Looking down in the hole the cam looks OK. I am going back out shortly here, and check it with my inspection camera.
Leon
Old 08-30-2024, 05:33 PM   #23
Getter-Done
Wow.
The pushrod beat up the snap ring.
I am thinking where are the Ears of that snap ring?
It probably won't make it back through they will drop to the bottom.
Is the oil pan Metal?
If so a magnet could be place in a position away from the oil pickup.
84 Chevy K-20
Old 08-30-2024, 12:03 PM   #24
mongocanfly
O wow..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-30-2024, 05:42 PM   #25
57taskforce
All about them K’s
How was the oil pressure??? That’s a massive leak.
Tyler
