08-29-2024, 06:50 PM | #1 |
62 GMC 3/4 ton Disc brake conversion
I know this has been beat to death already. The info is a little more limited on the 3/4 ton. Has anybody managed to get late model spindles on the 3/4 ton? It looks like the lower arm ball joint configuration is the issue as the upper looks like you can bolt in the later upper ball joint to mount the disc brake spindle. I would rather retain the torsion bars if possible. But otherwise is everyone thinking the 73 and up crossmember is better? What is different from a 71-72 cross member VS a 73 and up?
Thanks! |
09-01-2024, 02:55 PM | #2 |
Turning Wrenches Daily
Re: 62 GMC 3/4 ton Disc brake conversion
most guys are doing the entire squarebody engine cradle swap on the 60-62 pickups bud. you have to waller out a couple of the holes to get it ligned in but best and easiest way to do this.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 |
09-05-2024, 12:52 PM | #3 |
60-66 Nut
The most cost effective way to upgrade to disc brakes will be to swap the entire front suspension to a '71-'87 C20 front suspension. That will of course eliminate the torsion bars. The only other option is aftermarket spindles. I am assuming there are some for the '60-'62 C20's as there are for the C10's?
09-05-2024, 02:34 PM | #4 |
On my 62 one ton I was going to swap in an 84 c30 front to get disc brakes. I don't think they make hardly anything for the 8 lug setup at least for the one ton model. The joy of having a 3 year only front end. Then you want to change out to a new dual master cylinder and if it's a stick now a master cylinder for the clutch. It was just starting to snowball so I didn't change anything.
