Help Identifying SWB frame
I purchased this frame for a 72 c10 short bed build I am doing. It was advertised as a 72 frame. Can someone please help me confirm this before I spend time on getting this thing ready. It has front disk and drum rear. Its hard for me to tell the difference between the years as they as look so similar. Thank You!
![]() ![]() ![]() ![]() ![]() Last edited by Cmace22; Yesterday at 11:06 PM. |
Who Changed This?
![]() Join Date: Jan 2013
Re: Help Identifying SWB frame
'72 would have disc brakes. I believe that the serial number is stamped on the frame, but it may not include the year information. If you can't find welds or fish plates, it's probably the real deal.
All about them K’s
![]() Join Date: Jun 2014
The top of the drivers side front frame rail near the steering box should have a partial vin stamped in it. It will have the year, plant code and sequence number of the vin. As an example my 72 K20 has 72J160173 72 for the year, j for Janesville, and 160173 as the build sequence number; 1 is a check digit. Mine was the 60,173 truck to roll out of Janesville in the 72 model year.
If you’ve got front disks it’s most likely a 71-72 frame.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's |
It's possible they could have been changed, but t clam shell engine mounts also say it's '72.. As others have said, the numbers on the frame will tell the story...
#5 | |
![]() Join Date: Dec 2014
If betting were allowed I would put a dollar on that being a 1971 frame, built in Baltimore. Which if google is correct, is a city that is somewhat near you.
https://67-72chevytrucks.com/vboard/...28&postcount=7
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
