Old 09-07-2024, 11:20 PM   #1
Tipster_621
New Member
Any ideas what this might be??
I took apart the driver door to replace all the window trim, on my '71 GMC C1500, and found this laying in the bottom of the door. Any ideas as to what it might be?? It doesn't look like it goes anywhere inside the door and I haven't seen anything like it in the 2 or 3 door disassembly videos I've watched. It's a 1/4 inch steel rod with the 3 bends in it.
Tipster_621 is offline   Reply With Quote
Old 09-08-2024, 12:05 AM   #2
RustyPile
RustyPile's Avatar
Re: Any ideas what this might be??
It appears to be the torsion bar that engages grooves in the door hinge. It's there to hold the door in the open position.. The piece fits outside the door on the hinge.. My guess is it was dropped during door installation on the assembly line.. The "line man" dropped it in the door to avoid a reprimand..
RustyPile is offline   Reply With Quote
Old 09-08-2024, 08:39 PM   #3
Tipster_621
New Member
Wow, thanks for pointing that out! I hope they haven't done anything like that on my 2024 GMC!!
Old 09-09-2024, 02:49 PM   #4
damnyankee36
damnyankee36's Avatar
That's not quite the correct shape based on this photo. This spring was used on 1973-1987.
67-72 used this style of hinge, 2nd photo.
1966 C10 Custom Cab Restomod (Sold)
1969 Camaro Z/28 (Keeper)
Current Build: 1968 C10 (Semi-Factory Restoration)
1983 Camaro Z/28 (Next in line, Keeper)
1951 3100 (2nd in line)
damnyankee36 is offline   Reply With Quote
