![]() Join Date: Jul 2006
Correct screws for automatic column shift indicator housing?
What are the correct screws for the shift selector housing that sits on the column and where can I get them?
#2 | |
![]() ![]() Join Date: Feb 2009
Re: Correct screws for automatic column shift indicator housing?
The transmission control dial assembly’s (shift indicator) plastic lens inserts into its plastic housing. The housing mounts onto the turn signal housing’s top with two stainless #1 phillips countersunk oval head self-drilling screws. The screw threads are #8 x 5/16". Standard P/U screws may have been phosphate. If you're a paying member you can find originals on the parts board. Seems there would be replacements available, but sometimes replacement screws are junk, and pretty much always inferior OEM.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-13-2024 at 01:32 PM. |
