Old 09-17-2024, 03:50 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Bad PCV or grommet?
Leaking oil around the PCV. Nice round circle on the valve cover and slowly flowing down. The PCV still rattles but is VERY loose. PCV moves too easily in the grommet and comes out without a snug feel. Like the PCV is just sitting there. Thanks.
desert-rat is offline   Reply With Quote
Old 09-17-2024, 04:16 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Bad PCV or grommet?
It is a check valve, so put low air pressure on the side with the hose. If air flows, it is bad. Also, check to see how much blow-by you have. That's the usual contributor.
~Steven
Simi Valley, CA
Old 09-17-2024, 04:27 PM   #3
desert-rat
Dang! Hope all is good. Rebuilt motor has less then 500 miles.
Thanks. I'll definitely check it out.
Old 09-17-2024, 05:05 PM   #4
72SB
I have the same VC, my PVC is tight CV 744 C
72SB is offline   Reply With Quote
Old 09-18-2024, 12:10 PM   #5
kwmech
It will help the engine if the pcv system is a closed system. Have the other valve cover breathing filter air instead of eng compartment dirt
Old 09-18-2024, 01:48 PM   #6
HO455
HO455's Avatar
Sounds like a mis-match of parts and or poor manufacturing tolerances. I would break out my trusty calipers and measure the OD & ID of the pieces and then most likely try to locate a PCV valve that fit the grommet better.
RIP Bob Parks.
