Old 09-21-2024, 10:37 AM   #1
willem445
willem445's Avatar
Post Simplified 73-80 Lighting Circuit Diagram (Save For Debugging Issues!)
I ended up making a reduced & colored schematic JUST for the lighting circuit. I found this to be a great resource in debugging an issue I had.
My issue:
Turning on the right blinker caused basically every light to flash, including the gauge cluster. Eventually narrowed it down to the passenger taillight dual filament bulb. Somehow the "DK GRN-19" +12V signal was leaking into the BRN-9B wire. BRN-9B is shared between almost all of the lights and is used when you pull out the headlight switch and get the nighttime running lights (parking lights + side markers + license plate + gauge cluster backlight).
Debugging Tips
  • * Check all grounds (battery -> frame, alt support, radiator), (eng -> cab), (front lights -> rad support), (gauge cluster -> parking brake assembly), (fuel gauge -> frame), (taillights -> bed, frame)
    * Disconnect turn signal switch & use ohm meter to verify switch. (Right Turn -> Connection between dark green, purple, dark blue), (Left Turn -> Connection between yellow, purple, light blue), (Hazards -> Connection between dark green, yellow, brown, dark blue and light blue)
    * Use a jumper wire to isolate turn signal circuits on cab side turn signal switch plug. I tested purple -> yellow, purple -> dark green, purple -> dark blue, purple -> light blue. Purple -> dark green isolated my issue to the rear turn signal bulb.
Hopefully this information helps debugging any light issues people may have!
The square family:
1980 Chevy K20 Farm Truck
1977 Chevy K20
1986 Chevy K30 3+3 Dually
willem445 is offline   Reply With Quote
Old 09-23-2024, 09:27 AM   #2
Slammed84
Slammed84's Avatar
Re: Simplified 73-80 Lighting Circuit Diagram (Save For Debugging Issues!)
This is awesome, good work!
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 09-24-2024, 08:31 PM   #3
kitsbeach
kitsbeach's Avatar
Very helpful thank you
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
diagnose, lights, not working, schematic, turn signal
