Old 09-24-2024, 05:16 PM   #1
Fulcherma
Anyone have a low mount AC Comp on an LS
I have a 71 K20 that is getting a truck 6.0. I will be adding an aftermarket air system from one of the various companies. I'm looking for an ac compressor that will fit in the factory location on the engine. The factory one will fit, but there is no way the lines can attach to the compressor without hitting the frame. I have trimmed the frame some, but I'm not willing to go far enough for the lines to clear. I would really like it mounted low since I've already cleared the frame.
Is there such thing? It looks like the dirty dingo low mount could possibly work with the Sanden they sell. The lines come out farther up.
Does anyone have pics if they have mounted low?
Fulcherma is offline   Reply With Quote
Old 09-24-2024, 05:55 PM   #2
weq92f
weq92f's Avatar
Re: Anyone have a low mount AC Comp on an LS
I know I've seen low mount pumps on these trucks at the shows. Sanden makes pump heads with various outlet configurations and lines can be had that come directly off the head low profile and wrap around the pump to come out elsewhere.
https://coldhose.com/collections/san...mpressor-heads
https://www.carid.com/holley/a-c-com...199-201bk.html
EDIT: Have a look at this thread. The picture posted (link) shows a sanden low on an LS. The head they used shoots the lines off that way. Another head could shoot them off another way.
https://67-72chevytrucks.com/vboard/...d.php?t=768432
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-24-2024, 06:21 PM   #3
Orange Crate
Orange Crate's Avatar
Great people here...super nice product.
https://www.alangrovecomponents.com/Catalog.htm
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 09-25-2024, 06:29 AM   #4
Fulcherma
Thanks guys,
The end caps for the compressor looks promising, for sure.
Old 09-25-2024, 08:19 AM   #5
A1971Blazer
A1971Blazer's Avatar
Holley (Alan Grove) bracket with Sanden compressor
Down low and out of sight on my '67 with LS1
factory compressor would not fit
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-25-2024, 10:01 AM   #6
Fulcherma
Attachment 2394491
Attachment 2394492
Do you have any pics from the passenger side?
Old 09-25-2024, 10:52 AM   #7
A1971Blazer
Here's one
I bought a short hard line and bent it for the suction side, the high pressure side uses a 90º crimp on fitting on reduced barrier hose to go to the condensor.
The high pressure port is under the battery tray, just barely enough to connect to.
I also put the heater valve close by, you can barely see it under the hoses.
It's a close fit but I like how it's hidden away.
let me know if you want more pictures.
1967 C10 Step side
1968 C10 Step side
Old 09-25-2024, 02:37 PM   #8
bnorth
https://ls1tech.com/forums/conversio...71-c-10-a.html
Here's an example of a stock compressor with reworked lines.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 09-25-2024, 07:20 PM   #9
Fulcherma
Awesome guys, thank you! I'll try to document what I end up with.
Old 09-25-2024, 11:21 PM   #10
cleanfreak
cleanfreak's Avatar
I have a 68 with a 4.8 in stock v8 location , stock 03 ls compressor , clears. AC not hooked up yet , but a company called cold hose sells pn AA2209-AA2210 , LS fittings that put both lines straight out the front , looks like it will clear with no notching. If anyone has tried these I'd like to know , hopefully this winter is the winter I do the ac...
cleanfreak is offline   Reply With Quote
Old 09-26-2024, 06:49 AM   #11
Fulcherma
One of the guys above mentioned cold hose for compressor ends. I didn't dive into their site to see what else they have. Those fittings look like they may work. I'll probably order and see how they fit.
Old 09-26-2024, 07:05 AM   #12
cleanfreak
cleanfreak's Avatar
Were you planning on stock LS compressor?
Old 09-27-2024, 08:00 AM   #13
clay68c10
clay68c10's Avatar
Here ya go
https://67-72chevytrucks.com/vboard/...&postcount=341
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-27-2024, 08:37 AM   #14
Fulcherma
Originally Posted by clay68c10 View Post
Nice! That's exactly what I was looking for. I bought those fitting yesterday.
Thanks!
Old 09-29-2024, 06:32 PM   #15
1972CheyenneSuper
1972CheyenneSuper's Avatar
I used the Dirty Dingo low mount bracket set up and a Sanden style A/C compressor. I used this A/C line adapter with 45 degree fittings and cleared the factory curved lip. It does get a little funky with the water pump/heater core lines right above this, did the best I could with that situation.
1972CheyenneSuper is offline   Reply With Quote
