Old 10-04-2024, 01:38 AM   #1
BigRandy
BigRandy's Avatar
Replace old AC compressor with late model compressor
My Harrison A6 compressor went out. From what I can tell used ones are very hard to find, and no telling what shape a 40 year old compressor might be in, and anything new or rem'd is crazy high.
I was thinking, if I'm going to do the work and spend the money, why not use the compressor and brackets from a late model Chevy? At least late model parts would be easier to get when needed, and I'm not interested in keeping it original. I just want cold air.
I searched and found posts on converting from R12 to R134, replacing the compressor with a Harrison clone, etc.
The truck was converted to R134 before I got it so I don't know what all was replaced. A flush and new dryer would be a must. Will late model mounts fit my 454?
I would flush the system, replace the dryer, mount the late model compressor and recharge it to 80% of factory R12 spec, but my gut says I may be missing a lot more.
I don't see this being too difficult as long as I can use something with a v-belt from the 80's. I could also do serpentine and change everything if really necessary, or am I really opening a can of worms that I'm not going to like?
Repairing and driving old trucks is an analog experience. They have no computers or sensors and can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
Old 10-04-2024, 07:28 AM   #2
Bandit130
Bandit130's Avatar
Re: Replace old AC compressor with late model compressor
I replaced several reman compressors in 5 years. They just don't last. I got this sanden style in 2022 and have been very happy with it.
https://nostalgicac.com/a6-to-sanden...rsion-kit.html
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 10-04-2024, 10:35 AM   #3
Shifty One
Shifty One's Avatar
Did the Sanden SD508 swap after changing the r4 several times, one of which exploded, and filled my system full of doo-doo, which necessitated changing the condenser and evap core.
All is well now, and it cools extremely well, even in Tucson traffic.
Do it!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 10-04-2024, 10:39 AM   #4
Shifty One
Shifty One's Avatar
BTW, Alan Grove adapters are your friend.
Old 10-04-2024, 10:43 AM   #5
Jeepwm69
I need to do this to my 83 with a leaky R4, so tagging for info.
Jeepwm69 is offline   Reply With Quote
Old 10-05-2024, 10:50 AM   #6
v30crewcab
v30crewcab's Avatar
sanden is the only one worth running anymore.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 10-06-2024, 11:10 AM   #7
72malibu
72malibu's Avatar
Here's a pic of some Alan Grove bracketry with a Sanden style compressor. This motor has headers and I didn't want to bolt any accessory brackets to the side of the block. The original AC system and bracketry was also long gone.
I used both Alan Grove AC brackets and power steering brackets.
The trickiest part was finding the correct length power steering belt to orient the fill cap where I wanted it once the belt was properly tensioned.
72malibu is offline   Reply With Quote
