Old 10-06-2024, 05:39 PM   #1
54blackhornet
54blackhornet's Avatar
Dimmer Switch Screw Size ?
I need to chase the screw holes in the floor because of corrosion. Anyone help with the size of screws holding the switch ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 10-06-2024, 06:10 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Dimmer Switch Screw Size ?
Should be 1/4-20 NC.
Leon
Old 10-06-2024, 06:42 PM   #3
Getter-Done
Getter-Done's Avatar
It Mounts using two #3 Phillips panhead screws with star washers. The screw threads are 1/4-20 x 7/16.
The early bird gets the worm,
84 Chevy K-20
Old 10-07-2024, 11:46 AM   #4
54blackhornet
Thanks fellas ! I removed the switch because it failed. It’s been a while ago, when I went to install the new switch I couldn’t get the original screws into either of the holes. Will get a proper size tap to clean up the threads.
71 C-20
07 Magnum RT AWD
