10-07-2024, 01:01 PM | #1 |
Replacing Floor
I am replacing the floor in my 67. Three of the corners fit great, the bolt holes line nicely. But the passenger side B-pillar is way off, 3/4" gap. Hows a fella make up that gap, anyone had this problem and what was the fix?
10-07-2024, 02:41 PM | #2 |
Re: Replacing Floor
Before you removed the old floor, did you brace, including diagonal bracing, the cab including door openings??
10-07-2024, 03:32 PM | #3 |
Re: Replacing Floor
If you didn't brace, it leaves you in a similar situation to what I experienced. Wasn't replacing the floor, but my b pillars and cab corners were so rusted they were no longer connected to the floor. This allowed the upper part of the cab corners to flex out pretty far causing something similar. I had to pull the b pillars in on both sides and put the doors on to check fit. Took a while to get it back in shape.
10-07-2024, 03:58 PM | #4 |
Re: Replacing Floor
You will definitely want to dry-fit the doors in before you make anything permanent. Not the end of the world.
Edit: and you might find that the repop part just doesn't fit, and you will have to make it fit. Happened to me.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 Last edited by dagnabbitt; 10-07-2024 at 05:28 PM. |
