Old 10-20-2024, 10:42 AM   #1
R.O.B.
El Camino inner tie rod for conversion question
I've seen a couple threads talking about this, and wanted to verify if it's accurate. While converting my 67 C20 to a C10, instead of using a 67 outer tie rod as an inner, and using a squarebody outer tie rod with the POL sleeve adapter in the middle, I could use a 75 ish El Camino inner tie rod and squarebody outer tie rod with a normal adjusting sleeve. Is this correct? It's just that simple? FYI, my C20 centerlink is from a manual steering setup if that makes a difference.
R.O.B. is offline   Reply With Quote
Old 10-20-2024, 12:10 PM   #2
Re: El Camino inner tie rod for conversion question
When I did my disk brake/spindle conversion, )a 78 c10) I just used the power steering cross link, idler arm and pitman arm as well as all 4 Tie rods and the sleeves from a 78. It made it easier for replacements. I knew the whole front end was 78 if I ever needed any parts
Old 10-20-2024, 04:54 PM   #3
R.O.B.
Cool, no offense, but I that doesn't answer my question
Old 10-20-2024, 06:07 PM   #4
I have not ueard anyone using the chevelle/el camimo tie rod asyou described. Always v10s if the different eras
I missunderstood your question. Thus my previous answer.
Old 10-20-2024, 09:50 PM   #5
RustyPile
RustyPile's Avatar
I've never done the conversion you're doing, so perhaps I don't know what I'm talking about... But here goes..
Starting point ---- 1967 C/20
Ending point ----- 1967 C/10
C/10 springs and shocks
Couldn't you change the ball joints to C/10s??
Install 71-72 C/10 spindles (disk brakes)
Install 71-72 C/10 center link, idler arm, and Pittman arm
71-72 tie rods - inner, outer, sleeve..
RustyPile is offline   Reply With Quote
Old 10-20-2024, 11:48 PM   #6
mr48chev
mr48chev's Avatar
Here is a rock auto comparison between the two. I finally found the ones with the most usable info.
I've never heard of that swap but the last time I had a 67/72 C 10 was 1989 and I'd have to look on the title to see how long I have had my 71 GMC 3/4 ton although it did cross my mind to to make a short box 1/2 ton out of it but it will tow my boat and car trailer as is.
My ongoing truck projects:
