10-23-2024, 12:58 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Turn signal issue.
For a 1972 C10
Regarding the left turn signal...only the tail light signal works. The fender and front bumper does not work. New bulbs also. Where about would I check or fix? Thanks. |
10-23-2024, 03:40 PM | #2 |
Re: Turn signal issue.
If the rear works, you know the turn signal and flasher are working. Start at the socket by checking ground. Then check backwards from the socket to the wiring harness looking for 12v.
EDIT: With a 72, the front turn signal should ground through the side marker light, IIRC.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-23-2024, 03:41 PM | #3 |
jinx! ;-)
1970 C10 Custom longbed 350/350 |
10-23-2024, 07:31 PM | #4 |
Yep; the majority of electrical issues I find on vehicles are bad grounds.
10-24-2024, 01:35 AM | #5 | |
For the following, refer to the wiring diagram for your truck. You might have an open in the light blue wire as it works its way forward to the light socket. Here's how to test the circuit. Do not disconnect the plug but locate the light blue wire at the turn signal harness plug. Turn on the key and the left turn signal.. With a test light or DVM, test for voltage on the light blue wire.. If no voltage, the T/S switch is bad.. If there is voltage, Remove the fuse box, and test for voltage on the light blue wire at the firewall connector as indicated on the wiring diagram. If you have voltage on both halves of the firewall connector, check for voltage at the bulb socket.. If you have voltage, check the ground path through the side marker light if it's part of the turn signals.. As always, check, check, check the ground paths. |
10-29-2024, 10:20 PM | #6 |
When I got my '69, most of the lights in it didn't work, and in almost every case the fix for the issue was corroded grounds. Mostly the wiring to the bulb carries the positive current, but ground just happens through the housing which gets corroded with time. 80% of my electrical stuff started working when I pulled the housings off and sanded all metal points clean.
10-23-2024, 03:40 PM | #7 |
FIRST, make sure the fender lamp is actually supposed to blink(some years it's a marker lamp)
Since you already know the switch works: I always start with verifying a clean ground(to the body) at the socket I'd then start at the bulkhead connector with a trouble light and "climb the ladder" out to the sockets. I religiously spray contact cleaner into every connector to clean it, then hit it with CRC 2-26 to prevent moisture from creeping back in(I'm sure other light oils work the same), and I don't even live in a humid climate :shrug:
