10-29-2024, 09:45 AM | #1 |
LS3 - 408 Popping - 6L80e not shifting ....
Having two separate issues
1. Have a Blueprint LS3 - 408 - makes 595HP engine almost 400 at the wheels - running a PSI Harness and a 6L80e trans - full length headers into dual 3'' stainless exhaust with "X" pipe and 3'' BORLA ATAK mufflers. Engine has about 500 miles or so - oil changed since break in also installed new plugs and Scott's Performance wires. Question that I have - when accelerating at roughly low to mid throttle input the engine wants to pop through the exhaust - this is especially noticeable right before it shifts. Been to the tuner twice and he states it is not running lean and that it is impossible to tune it out 100% I'm at a lost here - thoughts suggestions. 2. Have a 6L80e behind a LS3 - 408 - the transmission has a Yank Pro Truck 3200converter in it and is being controlled by a PSI Harness Question - if I am driving the truck normally - the trans shifts normally ( all the way into 6th gear). However if I accelerate hard, do a burnout, ect..... the trans will not shift all the way into 6th - seems to shift to 5th and just stay there. If I stop and shut the truck off, restart it and take off all seems to be normal ?? The other day the trans wouldn't shift out of 2nd gear( I think it was in 2nd) ....... drove for a mile or so - shut it off.... restarted it... all seemed fine and shifted all the way to 6th Ideas on the cause of this ?? Any help on either of these issues ???
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
10-29-2024, 09:46 AM | #2 |
Re: LS3 - 408 Popping - 6L80e not shifting ....
everyone loves pics ....
10-30-2024, 10:12 AM | #3 |
I would find a new tuner
10-30-2024, 11:27 AM | #4 |
10-30-2024, 01:44 PM | #5 |
I don't disagree with you guys - its odd however as I've known this tuner to be super reliable per a bunch of people
Anyone know a tuner in the Northwest Indiana area ?? LS3/ 6L80e with a PSI Harness
10-30-2024, 01:46 PM | #6 |
Here is a plug I pulled
10-30-2024, 02:20 PM | #7 |
Maybe this will help, some transmission tuning information.
https://www.youtube.com/watch?v=8PCjGINa100 Full throttle in 6th gear? I don't know your gear rations, but the speed has to be very high. Will the Blazer do 160mph? You have an absolutely gorgeous Blazer. |
10-30-2024, 03:29 PM | #8 |
I'll try to clarify the transmission question - I'll watch the video, appreciate it
If I am driving the truck normally - the trans shifts normally ( all the way into 6th gear). However if I accelerate hard from a stop ( 1st gear maybe 75% throttle) the trans will not shift all the way into 6th - seems to shift to 5th and just stay there. If I stop and shut the truck off, restart it and take off all seems to be normal ?? The other day the trans wouldn't shift out of 2nd gear( I think it was in 2nd) ....... drove for a mile or so - shut it off.... restarted it... all seemed fine and shifted all the way to 6th
10-30-2024, 04:06 PM | #9 |
No help with the 6th gear issue but if you duplicate the 2nd gear issue with your tuner in the vehicle with his laptop plugged he should be able to see? the issue.
11-01-2024, 10:44 AM | #10 |
pic is blurry, but that plug looks to show a lean condition based on the porcelain being charred
11-01-2024, 12:22 PM | #11 |
I agree - plug looks a little lean to me as well
11-04-2024, 01:27 PM | #12 |
What management system is running this, holley, factory, FiTech??
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-04-2024, 06:00 PM | #13 |
Running on a PSI harness with a HP Tune
11-05-2024, 08:10 AM | #14 |
So a stock ECU, harness doesn't make a difference unless there's a mixed up wire, but you'd have a constant problem, not intermittent. I would reach out to another tuner, or even the HP tuners message boards and see if someone can look over your tune file. I'm not super familiar with HP Tuners. But your combo isn't something crazy or extravagant, should be very run of the mill. Probably a simple setting that needs to be tweaked. Also are you sure there are no exhaust leaks before, or near your O2 sensors?
11-08-2024, 10:49 AM | #15 | |
11-05-2024, 08:46 AM | #16 |
Do you happen to know what your fuel pressure is? Do you have an adjustable regulator?
11-05-2024, 11:14 AM | #17 |
Have tires or gearing been changed since the last tune for the trans? There is a different trans map for WOT, so readings may be going off the map before 5-6 shift if you have changed gearing
HPTuners has several forum posts on similar issues, read through all those and you'll probably know more than I do about how it works intermittent stuck 1-2 shift could also be low fluid or a sticking check ball, cracked valve body...it could be a separate issue |
11-08-2024, 10:56 AM | #18 | |
No in regards to the tire/ gearing all is set for 37'' tires with 4.56 gears I'll check fluid level Maybe the HP Tuner will log something that is notable
11-08-2024, 11:54 AM | #19 |
The Older Generation
I would try unplugging the main harness connector on the transmission and plug it back in, making sure it is seated all the way in. I was having shifting issues with my 8.1/Allison combo and that is what my problem was. Just a shot in the dark but it doesn't cost anything to try it.
11-08-2024, 09:04 PM | #20 |
Active Member
It sounds ridiculous…..but ohm out from the ECU, to each individual coil trigger wire on all 8 cylinders to make sure 1-1, 2-2 etc.
I bought a set of coil harnesses online somewhere, that were mis-wired. It would idle ok, drive Meh ok at low throttle then all hell broke loose at WOT. An infared gun at idle on each header tube was the first indicator. I had say 200* on a couple runners, and 120* on 2 others. Plugs were just firing whatever off-time residual fuel was in the cylinder. They weren’t dead, and it didn’t show up much at idle. Maybe you have a similar situation and that’s causing stuff to go into Help Me mode and not shift right? Just a thought…. |
11-08-2024, 10:50 AM | #21 |
Yes adjustable very close to the fuel rails - set at 60psi at idle - all new fuel system - Areamotive Pump, filter and regulator with a return line
11-08-2024, 10:54 AM | #22 |
pic
11-12-2024, 08:51 AM | #23 |
You need a way to log or view what the fuel pressure is doing under load. My Camaro would hold 55-60 psi all day at idle, light driving, and free revving, hammer on it and it would drop down to under 10psi. The ECU did everything it could to keep the engine running, found a leak inside the tank from the pump line, fixed it and fixed the issue I was having. New doesn't always mean it works. Not saying you did anything wrong, just never hurts to verify.
11-13-2024, 08:58 AM | #24 | |
11-14-2024, 01:46 PM | #25 |
All about them K’s
Reach out to GPI. They are the among the best of the best in my honest opinion with the combo you are talking about. Their bread and butter is modding 5th Gen Camaro’s, SS sedans, and all the new LT stuff. Ryan can do a remote tune that will be better than 90% of most local shops dyno tunes.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
