![]() Join Date: Jul 2001
Let's Talk Headlights
Having an OBS '99 Tahoe, like most, my original GM plastic lens headlights have faded and yellowed thru the years. I don't do a lot of driving at night being retired but here in the flat lands of Kansas when one is driving at night traveling deer and other wild life is a constant possibility. I know there are "kits" that one can use to remove the fade and some what clear the head lights to a point but that seems it is not a "one and done" type fix. Hence the question here:
Is it possible to purchase and install direct fit and function GLASS head light housings for an OBS '99 Tahoe? I'm sure actual glass head lights will be at a higher price point but a "one and done" type install is my goal. Any tips, info or help in this situation is greatly appreciated.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: Let's Talk Headlights
I was not able to find replacements that weren't the same as OEM which is not glass unfortunately. The prescribed method you already mentioned is likely the easiest way to get past the current issue....temporarily. Maybe fix them and then apply a ceramic coating to protect then just maintain that as needed. Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Kevin, thanks for the reply. Not what I wanted to read but then that's not a new situation now days at all. Any thoughts on replacing the current plastic housings with new replacements? Are there after market housings that are better than original GM which rarely is the case? Just don't think I want to waste my time and effort to try an clean these in their current condition. Luckily, once I get them replaced the Tahoe sits in the garage out of the sun for most of it's time now.
I'm wondering if those headlights are the same material as all the other cars on the road. If so, have you tried any of the headlight kits? Now from what I understand is that the plastic is just oxygenized. They have the three sandpaper grits and gritty past. One step that i hears of is once you get it cleared up that you shoot clear coat to seal it. I did that and it worked for a couple years. The issue is now that not all clear coats are the same. I used the cheap stuff and from what i heard is that the cheap stuff does NOT protect against UV rays. It also doesn't have a hardener. They recommend 2K. The kind that is separated in the cannister. Sorry it's a little longwinded.
LMC has some decent lights. I thought someone did make glass ones for these trucks, but dunno who it was, and think it was rather expensive. Get some nice LED bulbs, makes a huge difference. I have Auxbeam and they are great...
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
Spyder makes glass headlights.
https://www.amazon.ca/Spyder-Auto-Ch.../dp/B004WMF8SG if you look around i've seen them cheaper than what amazon sells them for |
#7 | |
Mike |
Thanks for the replies, will look into the Spyder headlights. Any problems with the install or are they a remove the old, replace with the new Spyders, a plug and play install?
I wanted glass as well, but failed at finding them. I ended up using Brock Supply for new replacements, and PIAA bulb replacements.
https://www.brocksupply.com/en-us/
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
Plug and play. Just like the factory lights
Mike |
What wattage bulbs do they come with?
I replaced the housings & bulbs in my '99 CC SWB mid 2017 & they're now worse for the wear (<40k miles). I also just replaced the housings for my '07 Envoy Denali & man they put off so much more lighting vs. my truck. It would be nice to update the lighting when replacing the housings.
The only time MY 89 k2500 headlights get foggy is when they get full of water!
![]() ![]() ![]() ![]() For some reason the picture wants to load upside down!
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive! 1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now! |
#14 | |
Mike |
#15 |
Don't shoot me but I saw video where someone used a torch to clean up seats. Why not headlights?
| Bookmarks |
