Old 11-26-2024, 06:43 PM   #1
RustyBucket
RustyBucket's Avatar
Replace throttle cable??
How do I get the throttle cable grommet out of the firewall on my '71 GMC?? I can't find video or good picture that shows how to release it. Not an easy place for an old fat guy to work on. It whipped me pretty bad this afternoon. Old cable is too long & kinked. Thanks in Advance!
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 11-26-2024, 07:27 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Replace throttle cable??
There are two barbed tabs that have to be squeezed inward simultaneously while pushing the cable out of the hole. You can't do one and then the other because the cable will tilt in the hole and get jammed.
pjmoreland is offline   Reply With Quote
Old 11-26-2024, 09:16 PM   #3
RustyBucket
THANKS!!!! A picture is worth a lotta words... & videos TOO. The pedal side is recessed so that I couldn't see the tabs. I've used hose pliers on my TV cable tabs. HAPPY THANKSGIVING!!!!!
Current toy trucks:
Old 11-26-2024, 11:11 PM   #4
Kalums
I've got a 71 GMC K2500 what/who's cable did you go with and do you know of a gas pedal return spring (the spring that makes the pedal stand back up) replacement? Also I'm glad you were able to get yours figured out *thumbs up*
Kalums is offline   Reply With Quote
Old 11-27-2024, 12:25 AM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
I got my new cable for my 72 k2500 from the truck and car shop
http://www.truckandcarshop.com/6072.html
Be sure to get one for 4wd, they are different length. Not sure if 71 is different but on my 72 the throttle return springs at the carb pull the cable and put the pedal back into position
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 11-27-2024, 12:30 AM   #6
Kalums
Thanks for the link and info on the cable. I've got the throttle return spring on my carb also... But my skinny pedal has a little coiled "V" shaped spring under it between the mounting plate and the pedal itself. *shrugs* it is really weak and I have been trying to figure out if it is replaceable or even needs to be replaced... Not much info around on it.
Old 11-27-2024, 11:18 AM   #7
Classic Bowties
Always on the hunt...
Kalums, we have these pictured GM NOS 1971-72 accelerator pedal pins and tension springs available in the below linked parts board f/s thread and also while on the same subject, here are a few more pics from our old saved folder archives showing the OE 71-72 style throttle cable to 4 BBL carburetor mounting bracket and return spring setup at the carb. Have a look and let us know, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=783148
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 11-27-2024, 11:33 AM   #8
Kalums
You rock! Sending PM
Old 11-28-2024, 04:07 AM   #9
RustyBucket
I removed the broken cable guide from the firewall(THANKS AGAIN pjmoreland).
All good info on replacing throttle cable on an original truck but mine has an alum intake and a small vac. secondary Holley carb. It's only about 10' from the firewall to the bracket on the carb. My cable housing is broken off at the firewall connection. The cable(braided wire) is fine but I wish I could find a a replacement cable housing or sheath approx the correct length. The pedal end of my cable has an adjustable stop nut. My cable housing broke because it was way too long and was in a bind.
Current toy trucks:
