Old 11-29-2024, 09:27 PM   #1
botoepfer
Active Member
botoepfer's Avatar
12 bolt being added to our 63
At another time in a Land far, far away I began collecting parts for a Hot rod truck build, one of those parts is a 12 bolt rear it has two eye on either side of the Differential I figure are for a factory four link. Our 63 has trailing arms with coil springs, can I, should I use both? thanks in advance this is new for me
botoepfer is offline   Reply With Quote
Old 12-01-2024, 01:36 AM   #2
leegreen
Re: 12 bolt being added to our 63
You can't use both.
Either weld the truck style trailing arm mounts to that rear end or convert your truck to use 4 link like the car the axle came out of.
If there is a problem with your current rear end probably easiest to find a newer trailing arm rear end and swap.
leegreen is offline   Reply With Quote
Old 12-01-2024, 11:32 AM   #3
botoepfer
Active Member
botoepfer's Avatar
thanks very much for help
Old 12-02-2024, 04:31 PM   #4
RustyPile
RustyPile's Avatar
Another item to consider... The wheel bolt patterns are vastly different..
RustyPile is offline   Reply With Quote
Old 12-03-2024, 11:07 AM   #5
botoepfer
Active Member
botoepfer's Avatar
Thanks I have swapped out my front cross member to an 83 C10, I will check the 12 bolt to be sure they match Good point indeed !
Old 12-04-2024, 12:22 AM   #6
RustyPile
RustyPile's Avatar
If that 12 bolt is from a passenger car, the bolt pattern is different.. Passenger car is 4.5X5, while 71 up C/10s are 5X5.. Pre '71 is 5X6...
leegreen offered the very best advice/solution.. Locate a good '71, '72 coil spring rear assembly.. It's a unbolt - bolt up project. Plus the wheel bolt pattern matches what you have on the front.
Old 12-04-2024, 10:45 AM   #7
SCOTI
SCOTI's Avatar
Passenger car 12bolt is 5x4.75 pattern.
Trucks were 6x5.5 or 5x5.0 depending on the year model.
71-72 12bolt 5x5 pattern rear ends are wider vs what was under a '63 so there are slight differences in back space requirements on wheels depending on final ride height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
