Old 12-11-2024, 09:05 PM   #1
DamnNearBlindGuy
Post Converting Eaton H052/72 from 8 lugs to 5
Hey everybody,
This is my first restoration and I need a little guidance. In my infinite wisdom, I decided to wait until my vision got really bad before I started this project just to make it challenging.
So here’s the deal. As mentioned above, I want to convert my Eaton H052/72 rear end from eight lugs to five lugs. The lowering kit I’m going to use in the front suspension only comes with five lug rotors. I don’t want five in the front and eight in the back. Nor do I want to use an adapter. That seems kind of Mickey Mouse to me.
Rough stuff has a Disc Brake Conversions For the eaten and they’ll sell me a Ford 9 inch rotor and there 5-1/2 inch five lug forged hub, but I think it unlikely that they’ll bolt together slick as snot. I’m sure there’s going to be machining involved.
In any event, Any guidance, information, suggestions, whatever, etc. would be greatly appreciated.
Good luck on all your bills and happy trails.
Regards, Jeff, a.k.a. Blind Guy.
DamnNearBlindGuy is offline   Reply With Quote
Old 12-11-2024, 11:51 PM   #2
franken
Re: Converting Eaton H052/72 from 8 lugs to 5
You may want to look into a diff swap. Do you have trailing arms or leafs?
Old 12-12-2024, 03:17 AM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Not gonna happen. You would need a custom hub made to accomplish this. As Franken said swap the rear end for something else.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 12-12-2024, 10:26 AM   #4
raggedjim
raggedjim's Avatar
From your other post I'm thinking you have trailing arm suspension with helper springs. If this is correct then franken has the right idea. A complete rearend out of a 71-72 with trailing arms would be the easiest way to get 5 lug in the rear.
You could also use a rearend out of a 73-87, cut off the leaf spring mounts, and weld on the trailing arm mounts (https://www.ebay.com/itm/28404274110...8aAp8bEALw_wcB)
There are kits to convert to disc brakes if that's what you want. I've done it, but didn't see any better braking than the rear drums.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 12-20-2024, 07:55 PM   #5
DamnNearBlindGuy
Hey guys,
Thanks for all your responses. Seems like the only way for me to go is to swap the rear ends. Next challenges where do I find a ‘71 or ‘72 14 bolt rear end? Does anyone have any suggestions on how to locate This item and what a reasonable price would be?
Once again, your help is greatly appreciated.
Regards, Jeff.
Old 12-20-2024, 08:00 PM   #6
DamnNearBlindGuy
BTW: you are correct, I do have a trailing arm with coil spring rear suspension.
Old 12-21-2024, 10:56 AM   #7
57taskforce
All about them K’s
57taskforce's Avatar
There’s no such thing as a 71-72 14 bolt. They were introduced in ‘73. Even if that axle did exist, you’d be in the same exact situation as you are with the HO52 because they are both full floaters. (Assuming we are talking 10.5” 14 bolts here) What the guys are saying is to swap in a 1/2 ton 12 bolt 2wd rear to match your front 5 lug pattern.
Tyler
